Old 9th September 2010, 06:10 PM
thebluewhale's Avatar
I had my screen replaced in May by Auto Windscreens.
Apart from the nightmare I had with the office explaining the details it went very smoothly.
The guys who changed the screen were spot on.
When I showed them the thread about the noisy screen, he fitted some thicker sponge he carried on the van and the windscreen trim was supplied as well.
It's been fine since, and the guys did a first class job. Couldn't fault them.
Old 20th September 2010, 07:32 AM
GlynH GlynH is offline
Thanks for the replies guys...
No-one has the part number for the thicker sponge from Audi then?
Is it even an Audi part??
Is the windscreen just bonded in place and is there a special sealant for bonding to an aluminium body?
End of questions...
Thanks & regards,
-=Glyn=-
Old 20th September 2010, 09:26 AM
Part numbers required:
b 357 845 955 Cutting wire for removing windows
b DA 004 600 A2 2k-window adhesive set
b D 009 200 02 primer for glass and paint
b D 009 401 04 cleaning solution
b D 000 703 A1 One set glass metal adhesive
The foam is
8D0 845 237 distance piece (self adhesive) 10x5, 5x6,3 lower (3 of)
443 877 665 C Buffer (self adhesive) 11x5 mm upper
Nothing stopping you doing it now Glynn!
Old 20th September 2010, 09:51 AM
Jesus wept...no wonder they call you 'Conan_the_Librariann'
<deliberate typo as you got my name wrong as well>
Can I be cheeky and ask what windscreens were available for my car please?
The reason I ask is National Windscreens tell me the heated screen was never an option in the S8...I am told mine will be green on grey/no mirror boss or something like that...
I really must get around to installing ETKA/ELSAWin here one day...
Thanks & kind regards,
-=Glyn=-
Old 20th September 2010, 12:20 PM
-=Glyn=-, Ok (now I will get you mixed up with =-Glyn-=)
Heated front windscreen is:
4D0 845 099 CS
There a 6 different front screens only one heated.
The sealing strip is actually 4D0 863 197 A (25x11) or C (15x15)
Old 20th September 2010, 09:17 PM
I had a heated front screen in my FL S8. Twas brilliant. Ensure that you get the athermic? metal lined screen.
Old 20th September 2010, 09:24 PM
You got one already? If not, then there's a whole load of extra stuff needed.
