Old 23rd May 2015, 11:46 PM
sparksuk's Avatar
sparksuk sparksuk is offline
Default Xenon range module
Hello guys
i'm having a problem with the Xenon range module on my Audi A8. ( 4L0 907 357 ). Bought it from internet, but i cannot locate it...? Where can i find it ?
Old 24th May 2015, 12:02 AM
Originally Posted by sparksuk View Post
Hello guys
Try page 172 & 173 of this document -
http://forum.a8parts.co.uk/attachmen...3&d=1420367344
Old 24th May 2015, 09:40 AM
Behind the instrument cluster
Old 24th May 2015, 06:37 PM
sparksuk's Avatar
Default Re
Oh, that is the last place where i did not looked for it ! I have open everyghing, B pillars, glove compartiment, under steering, etc.
So i need to remove the instrument panel, to find it ? I hope will be there
Thank you gents !!
Old 6th June 2015, 09:46 PM
sparksuk's Avatar
Default Re
Right. Found the sensor, replaced. But still same problem. The scan it said about the right headlight motor, i tried the connections, all looks ok. Could be the motor or the sensors on the suspensions ? Where can i find the suspension sensors, and how to check / acces them ?
Thanks
Old 7th June 2015, 09:02 AM
Why don't you post a copy of the scan so we can see what's going on,
If you had level sensor issues it would effect both lights not one, so my feeling is you actually have a problem with that headlight
Old 29th July 2015, 05:09 PM
Crazy_Guitar Crazy_Guitar is offline
Jesus, this is GOLD!!!
Any of you have these for the 2006 Q7 4L?
Old 29th July 2015, 05:33 PM
This is all there is for Q7 so far, http://forum.a8parts.co.uk/showthread.php?t=9924
if you find anything on your travels it would be great to have it added.
If your needing stuff in a hurry then pay for access to Audi erwin for a day and download everything you can for Q7
If not so much of a hurry you can go through the pain of downloading Elsawin and installing it.
Old 1st November 2015, 09:27 PM
sparksuk's Avatar
Default Sorted !!
Thanks guys ! the wiring diagram helped me a lot. took apart the whole driver side headlamp and checked everything. i found rusty connections on the main connector, WD40 on them then all sorted !
