Old 6th August 2015, 03:15 PM
genmaxiu genmaxiu is offline
Default Need help with errors
Hi,
Can someone shed a light on these error codes? I suspect a turbocharger but not too sure, obviously flashing glow plug light and check engine ON.
Tuesday,07,July,2015,19:39:14:33490
VCDS Version: Release 12.12.3
Address 11: Engine II Labels: Redir Fail!
Control Module Part Number: 4E1 910 409 A HW: 4E1 907 409
Component and/or Version: 4.2L V8TDI G000AGSª0070
Software Coding: 0011773
Work Shop Code: WSC 00752 210 91076
VCID: 224D9CD3FD4D230EAD9-8077
2 Faults Found:
005462 - Charge Pressure Control
P1556 - 011 - Negative Deviation - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 0
Fault Frequency: 6
Reset counter: 255
Mileage: 171937 km
Time Indication: 0
Date: 2015.07.05
Time: 11:33:59
Freeze Frame:
RPM: 2037 /min
Torque: 491.4 Nm
004455 - Mass Air Flow Sensor 2 (G246)
P1167 - 001 - Implausible Signal
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 171948 km
Time Indication: 0
Date: 2015.07.05
Time: 11:50:04
Freeze Frame:
RPM: 1260 /min
Torque: 3.9 Nm
(no units): 76.0
(no units): 100.0
(no units): 16.0
__________________________________________________ ________________
Tuesday,07,July,2015,20:15:30:33490
2 Faults Found:
P1556 - 011 - Negative Deviation - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10101011
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 171969 km
Time Indication: 0
Date: 2015.07.07
Time: 19:55:46
Freeze Frame:
RPM: 1848 /min
Torque: 471.9 Nm
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 171974 km
Time Indication: 0
Date: 2015.07.07
Time: 20:03:34
Freeze Frame:
RPM: 1428 /min
Torque: 3.9 Nm
(no units): 88.0
(no units): 116.0
(no units): 44.0
Tuesday,07,July,2015,19:38:18:33490
Address 01: Engine Labels: Redir Fail!
Component and/or Version: 4.2L V8TDI G000AGMª0070
4 Faults Found:
000257 - Mass Air Flow Sensor (G70)
P0101 - 002 - Implausible Signal
Freeze Frame:
Fault Status: 01110010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 171965 km
Time Indication: 0
Date: 2015.07.06
Time: 21:42:02
Freeze Frame:
RPM: 1050 /min
Torque: 3.9 Nm
(no units): 64.0
(no units): 120.0
(no units): 8.0
004104 - Mass Air Flow Sensor 1/2
P1008 - 000 - Implausible Signal
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 171967 km
Time Indication: 0
Date: 2015.07.06
Time: 21:44:54
Freeze Frame:
RPM: 1260 /min
Torque: 3.9 Nm
(no units): 1.74
(no units): 100.0
(no units): 100.0
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 171968 km
Time Indication: 0
Date: 2015.07.06
Time: 22:00:46
Freeze Frame:
RPM: 1701 /min
Torque: 292.5 Nm
and some logs:
http://vaglog.pl/log_224272.html
http://vaglog.pl/log_224273.html
http://vaglog.pl/log_224274.html
Any help much appreciated.
Thanks
Old 6th August 2015, 09:31 PM
Can you hear any hissing when under boost e.g inter cooler or associated pipe work leaking boost
Look at both air flow meter signals and compare on the road to see the difference ,if one is way off to the other .
Negative deviation is a fancy term for boost being low for given load factors .
Try to look at both turbo actuators get someone to turn ignition on and off and see if actuators do a 'full sweep' with a smooth action ,or see in the vcds actuations menu to see if you can drive them .
Air mass meters rarely give codes because the signals have to go through such varying load factors ,the air mass signals are not interrogated by ecm control , it's the consequential effects of it that the ecm picks up on such as wastegate control
If the turbo wastegate controllers are electronic they should flag codes because they have feedback to ecm e.g if the variable vanes where sticking
The 3l v6 jags flag 'p134b turbo control fault 'when it sees sticking vanes or high load feedback on the motor controller .
A few things there to go at
Old 10th August 2015, 09:43 AM
Thanks for the reply.
Will give a to-do list to my friend , I am not too good if it comes to mechanics (IT geek).
Old 10th August 2015, 12:30 PM
Your work in It ......oh in that case switch it off an on again ....be reet
Old 12th August 2015, 11:06 AM
Ok, light blue smoke from the left exhaust pipe doesn`t sound good, does it sound like turbo to be replaced? How much would it cost to replace the turbo (labour cost) ?
Old 13th August 2015, 09:54 PM
Could be turbo failed , never done one but they look arkward to do
