Old 12th August 2015, 12:47 PM
Default Leaky S8 lumbar support - can it be fixed?
It's beginning to annoy me that the lumbar supports in both my front seats (S8 Recaro Sports seats) deflate fairly quickly.
Having just read a thread on another forum about fixing a different design of Audi-fitted Recaro it has spurred me into investigative mode.
That seat was fixed fairly easily by dismantling the seat, removing the pump unit and sealing a crack that had developed in the plastic body at a connection point. I'm thinking that the S8 seats may use basically the same pump and have the same problem.
So does anyone have any idea how to get into these big heavy beasts (ideally in situ) in such a way that they can be reassembled afterwards?
Old 12th August 2015, 01:35 PM
The only way I can think of getting to the lumbar support air cushion and pump is to remove the sear pad, and then remove the middle backrest insert. Both are only hooked/velcroed on but the hooks are really difficult to get to.
This thread has some pictures.
I would remove the middle seat pad insert first, then the middle backrest insert (hardest).
I forgot, the inner seat cushion is zipped at the back to the backrest outer leather (the one with side bolsters).
This zip is secured at either end by big staples which have to be removed, it is a bit tricky to unzip.
http://forum.a8parts.co.uk/showthread.php?t=6302
Old 12th August 2015, 01:48 PM
I even posted in that thread, but forgot!
Old 12th August 2015, 02:16 PM
Welcome to my world!
Old 15th August 2015, 08:45 AM
Duffy Duffy is offline
I had this done on my D2 S8 in my first week of ownership.
There was no way of doing this in situ. On the bench it appeared relatively straightforward to strip it down and replace the cracked connection block. The part number for that was 4D0959931 and it was 3 hours labour to fit.
1988 Audi 90 2.2E
2011 Mercedes E250
2016 Abarth 595 Competizione
2012 Porsche 981 3.4S PDK mid life crisis!
Old 17th August 2015, 12:33 PM
My first ever A8 had this fix done under warranty too, but it was a seat out job for sure....
I concur with your annoyance.
Its quite a rare occurrence for the seat to fail, might be worth considering a whole replacement drivers seat for ease of fix, or even buy a cheap crappy one to practise dismantling first....
