Old 20th August 2015, 03:18 AM
mcs's Avatar
mcs mcs is offline
Default Headlight Level
Interesting problem...
Sometimes the LH headlight won't self adjust after the car has been switched on. They drop down, and then back up in normal operation, but more frequently, the passenger side one drops down and doesn't come back up.
It is very annoying. No ranger control errors or anything of that nature, so I am unsure what it is. Is it just a bad motor?
Mike
04 A8 - 4.2 Sport
Indigo Leather Sports Seats - Sports wheel - Sports Air Suspension
Auto Boot - Double Glazing - AMI - Solar roof
TV - Bose - Voice Control - TPMS - AFS- TINT
Power Blind, Fingerprint - Light package (in and out)
Retrofits:
OEM Auto headlights & rain sensing wipers
OEM Bluetooth phone
Bluetooth Audio Streaming
Reverse Camera
OEM Aluminium Package
Auto boot close using remote/door button
Old 20th August 2015, 08:53 AM
That's an interesting one, if there's no errors reported could it purely be mechanical inside the headlight?
Old 20th August 2015, 09:06 AM
That's what I was thinking... if the motor is faulty you'd almost certainly see an error.
Might we worth a session with VCDS. Perhaps the output tests might try and cycle the motors and give more insight ?
Old 20th August 2015, 11:49 AM
mcs's Avatar
mcs mcs is offline
Interestingly, tonight I got in the A8 after not using it for 5 days, the suspension was in jacking mode as I left it there when I parked it. I turned the car on, the RH headlight went up as usual, the left pointed down. I turned jacking mode off and the front of the car raised.
After this, I restarted the car and both lights levelled correctly. I think the level sensor at the front is playing up.
Mike
04 A8 - 4.2 Sport
Retrofits:
OEM Bluetooth phone
Reverse Camera
Old 24th August 2015, 01:40 AM
mcs's Avatar
mcs mcs is offline
OK, I scanned the car, It provided no error messages. I also tested the lights with the VCDS, and they went up and down just fine.
My car sinks at the front when it is parked, and after a few seconds pumps back up again (around 5-8mm) when it is turned on. If the lights are in auto, then sometimes before the car is pumped up, the LH one will come on and point down. If the lights are turned to off, then they usually are fine because the car has levelled before they are switched on.
It's all very strange.
Mike
04 A8 - 4.2 Sport
Retrofits:
OEM Bluetooth phone
Reverse Camera
Old 24th August 2015, 07:40 AM
Ah so you have an issue with the adaptive suspension, that will create problems with headlight levelling as the info comes from the suspension height sensors.
Have you any faults logged for the level sensors or the level system in general like leaks, over temp etc.
If you do have a leak you run the risk of your compressor dieing trying to make up the loss.
