Old 23rd August 2015, 08:20 PM
Default Another Rear Caliper Seized /Bleeding ESP hydraulic pump
Well after all the work done recently (water pump/'stat, timing belt rollers, engine mount, output seal, exhaust) I went to drive to the airport and a shuddering seemed to indicate that the suspect rear offside caliper (I was having trouble with handbrake adjustment) had decided to clamp on. Turned around, went home, changed cars and made it to the airport. Having now returned I have removed the calipers to investigate. The piston in the offside one was hard to move in any direction using the appropriate tool or even pumping the brake pedal! After looking at the alternatives I decided to send both away for refurbishment with BiggRed.
I had been quoted £86 for a single remanufactured caliper by my local garage but BiggRed will completely refurbish both for £139 (£159 for electroplated or £189 for the premium powder coated). As I will re-fit them myself, I read up the Service Manual from the Tech dump on bleeding the system and there was the section on bleeding for vehicles with ESP. They use a VAG 1551 or 1552 to activate the ESP hydraulic pump. The question is - can I use VCDS do this?
Old 24th August 2015, 12:45 PM
Anybody?
Old 24th August 2015, 02:22 PM
Page 164 mate, says to select Basic settings, then group 002.
At that point you will most likely need to press the on/off/next button.
So go into module 3 ABS, then basic setting, select group 002,press the on/off/next button.
Pump should run for ten seconds, only do a max of three times then leave the unit to cool for a while.
Old 24th August 2015, 03:16 PM
Thanks Del, I guess that was the question - whether VCDS had the same functionality as VAG 1551. Thanks for clearing that up. All i need now is my calipers back. (Just been told that it will be around 7 days)
Old 24th August 2015, 07:35 PM
I thought I read somewhere that performing basic setting on your ABS pump can fubar the unit, at least have a look for this online David before you do it
Old 24th August 2015, 07:44 PM
Brake fluid change is one thing I would go to the dealer for, its not too bad £59 fixed price servicing. They have the special machine and can do it very quickly.
I replaced a rear caliper myself on the previous S8, but inevitably let some air into the system, and despite bleeding it, it still felt mushy. I didn't do the ABS pump bleed for fear of fubaring it as Neil points out. So I took it to the dealer and it felt fine afterwards.
