Go Back   A8 Parts Forum > A8 D3 > D3 - Common Faults
D3 - Common Faults Quick links to all known common faults and their solutions
Old 5th September 2015, 06:35 PM
Borys's Avatar
Borys Borys is offline
Default accelerator pedal stuck !!!!
Today kicked down s8 and woooow pedal got stuck!!!!
Scared hell out of me
Put it to N played with it a bit and it came back to normal
Any one had similar issue in the past maybe?
Kick down switch faulty?
Don't have my vcds yet
Old 6th September 2015, 07:06 AM
Concept Concept is offline
Had one a few years ago when my then boss (ex-England captain) rang me to tell me he nearly got killed as the accelerator got stuck on the M1....
I checked it when he got in, it had got stuck under the mat as he had managed to u clip the mat at some point.
Who said footballers have no brains?
2006 S8
Daytona Grey/Black Leather
B+O, Advanced Parking, Rear Blind, Thru Load, Homelink, Heated Rear Seats, TV
Resonated Milltek
Dream car since selling Audis in 2006, finally a reality.
Old 6th September 2015, 07:56 AM
Happened to me a few times back in the days of throttle cables, due to the cable becoming frayed and getting jammed.
With modern fly-by-wire throttle pedals, I would guess it's likely to be one of two things: A faulty throttle potentiometer or a mechanical problem with the pedal itself (broken spring, sticking pedal, etc). Did the pedal feel any different when it stuck?
Old 6th September 2015, 09:13 AM
If there was an electronic problem, the throttle system is designed to failsafe to zero - applying the brake will also override throttle demand.
Sounds most likely to be a linkage issue or a carpet mat getting in the way. Frightening either way when it happens in something with enough grunt to very quickly get you into trouble!
Old 6th September 2015, 09:20 AM
Don't remember which car it was but I had one where clutch pedal was getting stuck in the carpet if I pressed it too hard.
Old 6th September 2015, 10:00 AM
Borys's Avatar
Pedal feels totally normal
I don't see carpet being the problem its perfectly fitted to the floor
I'll check with engine off the full movement
