Old 7th October 2015, 06:33 PM
laketahoequattro laketahoequattro is offline
Default Rear headrest fuse
Is there a fuse for the rear headrests or lumbar support? The rear headrest adjustment buttons in my D2 are not adjusting, nor am I hearing the motor running. They are in the down position currently.
Have searched all over the net, cant find much info.
Thanks
2003 A8L Build Thread
D3 Turbine Reps – S8 Mani
2002 Allroad Build Thread
2005 Color Match - TDI 01E - TTV LWFW - RS4 PP - BW K04s - Stg 2 WMI - WB- AWE DTS - EFK - H-SPORTS - IPP Arms - S6 Alcantaras - 4K LB Hitch - V1
Old 8th October 2015, 02:04 PM
Rear seats should be fused from the fuse panel above the battery in the boot.... Check there first
Old 22nd October 2015, 03:30 PM
So I found the fuse and it had been removed. I put in a new fuse to find that all the lumbar supports and headrests in the back seat did not work. Someone must have removed the fuse to prevent damage.
I then later found that the head rests and lumbar support did not work in the front seats either!
So I took all the seats apart, shortened the housings around the cables. 6 hours later all work again. Slowly learning about my d2.
