Old 7th December 2015, 10:36 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Default Jump starting other vehicles
Hi all. Last summer I tried to jump start a lawnmower in France (as you do), with no luck. And today I tried to jump a friend's Qashqai thing. I wasn't expecting it to work, and it didn't! I had to tow her car to start it. She'd not done that before, so it wasn't as easy as you'd expect. But hers being a manual at least that option was available.
It got me thinking about if the D3 could jump start another car. I know the complex power management and the steel bar on the - terminal of the battery complicate things.
So, is it possible?
2007 Mini Cooper S R56
Old 7th December 2015, 10:47 PM
So, is it possible?
Yes - Positive to the battery, neg to the big metal post, used to do it loads in my D3
In the D4 you have a +ive and -ive terminal under the bonnet, although the battery is in the boot under the spare wheel! Works just the same
Old 7th December 2015, 10:56 PM
Johnmed's Avatar
I wonder why mine isn't kicking out enough juice then? I have tried two different sets of jump leads.
I've had better luck when jumping the D3 itself, after flattening the battery with VCDS (you live and learn).
Old 8th December 2015, 12:05 AM
I haven't read the manual about giving a jump but i suspect the battery managers diodes are preventing it from working properly, is it not the case of receiving a jump or charging it goes to the post, giving a jump is direct on the battery posts engine running preferably?
Defo read the manual though as i could be wrong
Old 8th December 2015, 07:05 AM
Also note that tow starting a modern manual is not recommended - it results in a lot of unburnt fuel in the catalytic converter which can damage it (assuming it's petrol!)
The usual barrier to a successful jump start is decent thickness wires. I've used my S8 to jump start a Rover 220 which was pretty straightforward, but if the car has a chunky motor or is a diesel it needs a really good battery and thick cable
Old 8th December 2015, 07:26 AM
Johnmed's Avatar
I didn't know that about tow starting a modern petrol. Thanks. I used my leads and my friend's. Both have worked to start her car and the D3 previously.
