Old 8th December 2015, 02:26 PM
Default D3 rear heated windscreen issue?
Ive noticed on my D3 that the rear heated windscreen works fine but when I have pressed the button it only seems to be on for a minute or two before auto switching itself off again, so I end up going through pressing it then watching the button for the light going off then re-pressing which is a pain.
Surely it should be on for longer than 2 minutes and if so why would it be cutting off sooner?
Old 8th December 2015, 02:31 PM
Come to mention it mine goes off quickly, although I've not timed how long. I'll look into it.
Matt
Old 8th December 2015, 02:46 PM
Rear window heater control
The convenience system central control unit activates the external rear window heating relay -J9 (relay coil). The information to activate the heated rear window is transmitted via CAN from the air conditioner operating and display unit. The air conditioner operating and display unit is the master unit in the heated rear window function and can, if necessary, initiate cyclic operation of the rear window heating via CAN. During starting actuation of the rear window heater is interrupted.
I'll carry on digging...
Matt
Old 8th December 2015, 03:06 PM
Cheers Matt not sure what they mean by "If necessary" lol
Old 8th December 2015, 03:11 PM
Indeed. A simple, timed 5 minute, on off would have been better. Over engineering at its finest to reduce the electrical load to save a teaspoon of fuel a year.
Matt
Old 8th December 2015, 03:09 PM
Actuation of heated rear window at temperatures below 0 °C stays on with no time limit until shut off at temperatures above 0 °C it is shut off after approx. 10 min.
Above 0 °C the rear heated screen is controlled by a complex algorithm of outside ambient temp, internal temp and humidity, and energy management.
Matt
Old 8th December 2015, 03:16 PM
So if mine is staying on only for 2 minutes or so then which component isn't functioning correctly and are there any tests on VAGcom to confirm this?
Old 8th December 2015, 03:21 PM
Ah... I've found more.... There is different coding for different engines and glass. Maybe yours is controlled to be time-limited between 2-20 mins
- Coding for vehicles with 8-cyl. engine and heat insulating glass.
- Actuation of heated rear window stays on even at temperatures below 0 °C but time-limited (depending on ambient temperature between 2 and 20 min).
Matt
