Hey guys,
1997 4.2Q A8. Ever since i've owned it (not that long) the park brake illumination light comes on, and the dash chimes after driving the car about 200m after turning the car on. Park Brake works perfectly, Start up check ok and no issues, .... I did search but couldnt find anything that matches my problem Ideas? |
I'm guessing the microswitch on the handbrake lever is faulty or out of adjustment, assuming the D2 has one.
No, it won't be that.
![]() My D2 had a faulty switch on the lever and all it does is control the warning light on the dash, no bongs or connection to anything else whatsoever. It's a very simple circuit with a normally-closed pushbutton mechanical switch that is pressed open when the lever is lowered. Bit of a pig to get at and replace so I (eventually) rerouted the wires on mine and fitted a sealed reed switch and magnet arrangement, as used in door/window open sensors in domestic alarms. Works fine after a bit of adjustment. Sounds more like the brake pad wear warning. ![]()
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 26th December 2015 at 09:06 AM. |
E-Brake / Park Brake shoes are still have a lot of meat on them, and still works very well. Havent checked the sensor, but I can do that.
Front Pads have previously set off the Wear sensor before, which is a different warning which comes up on the display |
There is no sensor on the rear brakes, just the loop through the front (inside) pads to detect wear.
Have you done a VCDS scan, might be ABS/ESP related?
Have you checked the brake fluid level?
