Hi everyone I have a problem with my a8 2.8.
The idle is lumpy, the revs do not fluctuate but the engine wobbles if that makes sense. The idle is a little low but it is the same until I Rev it past 1k rpm. The fault codes I have are 01120 camshaft adjustment 1 01121 camshaft adjustment 2 Am i rite in thinking this could be camshaft position sensors? If so does the cam belt have to be removed to replace them? Any other ideas will be greatly appreciated Thanks James |
I recommend having a look at the appropriate engine service manual in the Tech Dump in the D2 common faults section.
2002 D2 S8 – Ming Blue, Valcona leather, Vavona wood insert, solar sunroof (to be fitted), Heated rear seats, extended leather pack, 18” Avus, ski hatch, Bose, auto dim rear view mirror, rear blind. Last edited by Architex_mA8tey; 3rd February 2016 at 08:50 AM. |
You don't have to remove the belt to get to the back one. Not so sure about the front one, but I will have a look in an hour or so - I have a 2.8 in the workshop
![]() Those codes don't appear to be faults with the sensors though - they are usually specific, something along the lines of "camshaft position sensor G40 open or short to ground". They sound more like the ECU knows the cam adjustment isn't adjusting properly, as it can measure that with the position sensors. If both sensors had failed it wouldn't run at all, as the ECU would have no idea what the engine was doing. Are you using VCDS or a generic scanner though? |
Thanks for your help. I'm using a generic scanner.
I'll see if I can get my copy of vcds working to nite and report back James |
Yes, you can get to both without removing the belt
I have ElsaWin here are fault tables for a 2001 A8 2.8 printed into a pdf.
I could not find the codes you listed. Hopefully VCDS will give you the proper codes. |
