Old 5th February 2016, 10:30 AM
3.7 slp 3.7 slp is offline
Default symptoms of a bad starter
Hi all
ok what I have had for the past few months on a cold start is that most time regardless of if I use the stop-start button or the key is a long delay in the car firing up. I turn the key or push the button and for 3-4 seconds nothing and then she starts up and when this happen I also get the EPC light staying on. This is only from a cold start.
...I'm thinking starter motor ..but would like to know want the members think
....do the symptoms sound like the starter .
Thanks for the help and input all
Steve
Old 5th February 2016, 10:49 AM
Have you got a scan? seems like a strange fault your describing there and i struggle to see the connection so a scan would be the best place to start
Old 5th February 2016, 11:06 AM
Hi Yep sorry should have said my local specialist checked it out and it showed
1 electrical fault
2 starter not turning
I cant recall the code but that was what was shown.
also its a new battery fitted so have ruled that out.
Old 5th February 2016, 11:10 AM
yeah without a vcds scan cant even give you a place to start, starter not turning could be something else like a bad relay so would need vcds scan
Old 5th February 2016, 11:19 AM
They did do the vagcom scan and also replaced 2 of the starter motor relays. one was under the steering wheel and the other under the glove box. But did not seem to work.
Old 5th February 2016, 08:50 PM
I've seen this before on D3's and there's a thread somewhere on here where at least 1 person replaced their starter motor finally (which apparently isn't the nicest/easiest of jobs) and that cured the issue.
Having said that their issue related mainly to warm starts after using the car for a journey then re-starting again and there was a similar delay of a few seconds with no action and sometimes a click, then the car would start ok randomly a few times later
