Just thinking out loud here, but my 97 Quattro is up on stands at the moment getting new fluid tomorrow after throwing Code 17114
Very minimal trans fluid came out, horrible condition (188kms) so hoping new fluid might work. If not, well .. we'll probably rebuild it. That being said there is a possibility of acquiring an ABZ and 4sp Auto from a 95, the engine will be used for a project, but was wondering if the 4sp can be retro fitted, with TCU im assuming into the 97?
Aussie! Current Rides 1997 D2 A8 4.2L Quattro 1997 E38 740iL 4.4L 1998 Subaru Liberty Blistien Edition Previous 1972 Chevrolet Camaro, 671 fed 385cu 1996 E39 523i 1997 E39 528i 2000 GXE10 IS200 2003 Alfa 147 Twinspark |
Or also will an auto from a 2000 A6 4.2Q go in without issues?
What's in the 97 now? Elsawin shows it could be 4 or 5 speed. Like for like is going to be easiest, but whether the TCU would be happy all depends on the gear ratios as it monitors input and output speed to make sure all is well (which is what throws the 17114 code when it isn't).
If you post up the gearbox code, and the 95 A8 / 00 A6 if you know them I can look up what the ratios are ![]() |
Swapping from 5 speed to 4 speed will mean changing the rear diff, propshaft and presumably gearbox ECU. I think the instrument cluster is different too.
Probably doable if you have a complete donor. Nick |
5sp is currently in there.
Both the potential donor cars, A6 and 95 A8 appear to have been sold. Still havent filled fluid into the A8 here yet, so no idea bout if its dead. but thankfully we are doing an engine conversion and wanting to use an Audi 4.2L. Cheaper for the client to buy a running car, than just an engine so I hope to score the auto cheap ![]()
Just dipping my toe into the water, what sort of money do you want to give for a whole car minus the front seats.
