Just got my vcds system this morning, slowly getting use to everything, got the TPMS back on and working.
When I bought my car, the owner said the cruise control stopped working because someone made it so that you could watch TV while driving, and since then it doesn't work. Not sure if that's true or not, but ive got to sort it out now! When I go and pull the stalk (or any other direction) I just get " . . . " at the top of the display. Address 13: Auto Dist. Reg Labels: None Part No SW: 4E0 910 561 F HW: 4E0 907 561 F Component: ABSTANDSREGELUNGH03 0020 Coding: 0041154 Shop #: WSC 00508 210 83382 VCID: 25419FF9ECDE3A162D-8070 4 Faults Found: 01044 - Control Module Incorrectly Coded 000 - - - MIL ON Freeze Frame: Fault Status: 11110000 Fault Priority: 5 Fault Frequency: 254 Reset counter: 53 Mileage: 159872 km Time Indication: 0 Date: 2015.09.19 Time: 11:24:00 Freeze Frame: Temperature: 31.0°C Voltage: 11.01 V Bin. Bits: 00000000 01317 - Control Module in Instrument Cluster (J285) 013 - Check DTC Memory - Intermittent - MIL ON Freeze Frame: Fault Status: 10111101 Fault Priority: 5 Fault Frequency: 59 Reset counter: 93 Mileage: 160152 km Time Indication: 0 Date: 2015.09.21 Time: 07:34:00 Freeze Frame: Temperature: 10.0°C Voltage: 8.32 V Bin. Bits: 00000000 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent - MIL ON Freeze Frame: Fault Status: 10110010 Fault Priority: 5 Fault Frequency: 34 Reset counter: 93 Mileage: 160152 km Time Indication: 0 Date: 2015.09.21 Time: 07:35:00 Freeze Frame: Temperature: 10.0°C Voltage: 8.45 V Bin. Bits: 00000000 01316 - ABS Control Module 013 - Check DTC Memory - Intermittent - MIL ON Freeze Frame: Fault Status: 10111101 Fault Priority: 5 Fault Frequency: 13 Reset counter: 92 Mileage: 162648 km Time Indication: 0 Date: 2015.11.29 Time: 13:02:00 Freeze Frame: Temperature: 2.0°C Voltage: 8.45 V Bin. Bits: 00000000 Can someone confirm what the correct coding is for a 2005 w12? is "0041154" wrong? Or is the plot thicker than that... Thanks |
Have a look at my thread, you will find the coding info along with other stuff that may help you
http://forum.a8parts.co.uk/showthread.php?t=10419
Del ![]() |
Thanks, will go through what I have next time I'm in the car.
Success! The module was coded xxxxx4 instead of xxxxx5, someone removed the "add 1" for the rear seat entertainment.
Crazy to think one digit can screw up a £1500 option. |
Glad you got it sorted, coding can be a fickle thing.
Del ![]() |
