Because the car keeps forgetting it! It has been fine for a few weeks but has now got back into the habit of forgetting the date and time when parked up overnight. I'm going to scan it with vagcom today, see if that throws any light on the situation.
There is/was a software bug in the instrument cluster causing this.
Some years needed a coding change, some a software update. It especially happens if the headlight switch in not in 0 or auto when the ignition is turned off (ie headlights or sidelights manually on) I think it also happened when the indicator was left on (one side parking lights). |
I'll set the clock again and test it. Thanks for your help! Last edited by tgm147; 27th March 2016 at 06:15 PM. |
TGM147; If you have VCDS, I'd be interested in seeing what hardware and software versions it says for your ECU 17 - Instruments.
My 2005 A8 has lost the time numerous times over the years and its log looks like this: Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 950 F HW: 4E0 920 950 F Component: KOMBIINSTR. VDO H49 0200 Revision: D03 Serial number: AUDID3DN000886 Coding: 0000418 Shop #: WSC 00028 210 01865 ---------------------------------------------- Snapdragon - have you any references as to which versions needed what to fix this please? [I've already got the 0000xx8 coding that the 2005 cars need]. Regards - Julian |
Sorry, I just read online somewhere, and most of it has faded away
Same revision and HW/SW numbers! |
Part No SW: 4E0 910 950 F HW: 4E0 920 950 F Component: KOMBIINSTR. VDO H47 0200 Revision: D02 Serial number: AUDID3D6000058 Coding: 0000408 Shop #: WSC 00468 210 67755 VCID: 27587CDA96F6351 Heres mine i did the coding which should have fixed it, but didnt, Still goes back to 2004 if i leave the lights on , ignition off and open the door, not always but every now and again
