Old 24th January 2009, 10:49 PM
Default Airbag warning light - Passenger seat
Here is another very common fault, which seems to hit many D2's with the sports recaros after around 10 to 12 years of life, although it will certainly be based on the number of time the passenger seat is used.
How to diagnose:
The fault is diagnosed using vagcom on the Airbag controller, and expect to see a fault regarding the 'seat occupancy sensor' for the front passenger seat. It will likely be 'intermittent'
You can reset the fault, but it *will* reoccur, it might be a week, it might be a month, but it will.
What is the sensor for ?
The occupancy sensor is used to determine whether anyone is sat in a particular seat. The theory is, that if a seat is unoccupied, then in a crash it can deploy less airbags and reduce the repair cost. There is always a sensor on the passenger seat, and apart from the very early D2's, and the very last ones, there are two sensors for the rear seats too. The drivers seat has no sensor as its fair to assume in a crash that seat was occupied
Where is it?
The occupancy sensor is actually nothing more than a thin, flimsy pressure pad that is bonded on the seat foam underneath the seat covering. It is not a mecanical switch or push to make type contact, instead it is a pressure pad which gives a variable resistance depending on the load on the seat.
Does it affect non sports seats?
No, it doesnt seem to. The sports seats are unique in that the presssure pad is in two parts - It has one part on the main seat base, and another much smaller one on the pullout knee squab. It is this latter one that always seems to fail.
Can I just bypass it ?
Yes, See below
How can I fix it Properly?
The pressure pad is bonded onto the heated foam of the sports seat, and thus the whole item needs replacing. The part is approximately £200 from Audi. Expect to pay 2 / 3 hours labour to have it fitted.
Depending on how long you intend to keep the car, it may be cheaper and more cost effective to consider just buying a 2nd hand passenger seat without the fault. Check with us to see what stock we have.
Old 7th February 2009, 03:54 PM
sutherland sutherland is offline
No, because it generates a variable resistance and not just a simple short to ground, its just not that simple.
Surely someone can up with a bypass schematic that can be built and plug in under the seat. I see folk have done this for BMWs. I imagine that when the seat is being sat upon it creates a steady resistance or a resistance above a certain point that can be permanently replicated.
Can you advise which plug it us under the seat?
Old 7th February 2009, 09:01 PM
Interestingly enough.. Mine used to do this all the time '98 with Sports seats.
Had the ECUs disconnected when trying to get to the source of a leak, and also tightened the connections on the airbag ECU behind the centre console and it hasn't came back again.
Maybe just got lucky, but might be worth looking at the ECU connections to make sure they haven't worked loose. Are there extra wires to the sensor in the sports seats?
Old 7th February 2009, 09:10 PM
My 97 A8 has this snag. I've thought of taking the bulb out, but that's not really my style!
I'll have a shot at the connectors, Psyche, but surely all that's needed is to convince the car that the passenger seat is permanantly occupied?
Surely this could be done by shorting a couple of wires with a jumper?
Failing that, how to reset the system?
Ta
Old 7th February 2009, 10:19 PM
You can reset the airbag light using VAG COM, have done this. But it just comes back on
Old 8th February 2009, 08:55 AM
Its not a simple make or break connection, its a resistance value that determines whethe its occupied or not....
I do agree that it should be possible generate a fake resistance equal to the airbag sensor mat -
There is a unit available for BMW's that does just that, and I bought one last week so when I get chance to test it, i'll let you know.
The correct values for the pressure mat are well documented, so if someone is really handy with their electronics and can knock up the right resistance we may be on a winner... I'm ok with electronics, but draw the line at trying to make any sort of circuit that looks professional
