Old 7th April 2016, 08:56 PM
goldsax goldsax is offline
Default time taken to get to running temp?
2006 4.2 Tdi.
how long does it take members cars (4.2 tdi) to get to their running temp?i have had the car for about 2 weeks and getting to know it a bit better.
it was 5 deg this morning and took 15 mins to hit 80 deg.
normal?
if not thermostat
cheers raj
Old 8th April 2016, 12:50 AM
H-M3 H-M3 is offline
sounds about right, my one takes around that time i think
Old 8th April 2016, 07:23 AM
cheers for that .
another characteristic ticked..
Old 8th April 2016, 08:28 AM
Pretty sure mine wasn't super-fast to warm up either.
Old 8th April 2016, 09:42 AM
Webasto heater failures aren't uncommon on the Tdis.
If the heater isn't running, the block will take a very long time to warm up.
Working correctly though, and it should warm up in petrol-like times really.
Worth a VCDS scan to see if it has faults logged...
Old 8th April 2016, 06:45 PM
Lee S Lee S is offline
My drive to work is about 10 miles and 15 minutes and mine has probably warmed up halfway there, so about 7-10 minutes. That's mainly dual carriageway though and at 70mph (1800 rpm) but first 2 miles are through a couple of villages in a 30 zone. Can be a bit longer if its cold but not cold enough to fire up the aux heater (say 8 to 10 degrees). If it's like that I manually start my aux heater and then it's only 5 minutes to warm up. 15 minutes could be OK. Can time mine on Monday if you want with ambient temps etc? Also, do you have VDCS? You could test the aux heater and also enable the hidden menu and code in the aux heating AC menu, where you can manually start the aux heater.
Lee
2017 Nissan Leaf Tekna
