Old 8th April 2016, 06:33 PM
Darius Darius is offline
Default Possible air leak, where do I start?
So, Ive noticed that the rear drivers side corner drops a little overnight. After leaving the car for more than 48 hours, I think passengers side drops a bit too. Where do I start looking for this air leak? I have read about using soapy water, but will this help me find what seems to be a very small leak?
Also, few weeks ago I tried to calibrate suspension with no luck, after car is restarted it goes back to normal. Wonder if this has anything to do with this leak? Any help would be appreciated.
Old 8th April 2016, 08:01 PM
Try using VCDS to jack the offending axle to the max pressure allowed for that axle and then use soapy spray on connections and around the struts.
Use the label file from this thread to assist you
Old 8th April 2016, 08:06 PM
And I thought I searched a lot before asking the question. Thanks! Will give it a go tomorrow hopefully.
Old 8th April 2016, 08:16 PM
If you skip to 11:18 in this video you can see how the charging of the axle is done and what to look at etc.
https://www.youtube.com/watch?v=OU5SBmHQIfI
Just remember thats the front axle in the video
Old 9th April 2016, 07:06 PM
Well I had a go today, but no luck finding it. Is there anywhere else I could look for it? The only thing that keeps bugging me is what if the leak is at other side of the air bag? Frustrating this
Old 9th April 2016, 07:29 PM
Have you had the arch liner passenger side and soaped up the valve block?
