right now I have your attention. lol. With the help of my great friend Marcin I managed to get a full fault codes before and after reset on my 8. Can you lovely folks break this down to me in Noob term so I can see what needs urgent attention and what I can leave for time being.Log-H-M3 1ST SCAN-WAUZZZ4E36N015057-189800km-117936mi 1.txt
Log-H-M3 AFTER CLEARING FAULTS-WAUZZZ4E36N015057-189800km-117936.txt hope this works....????? |
sorry if anyone would be kind enough to edit this so it can be viewed on the actual page?
ta |
Saturday,09,April,2016,14:34:37:36862
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86 VCDS Version: 15.7.4.1 Data version: 20160216 www.Ross-Tech.com VIN: WAUZZZ4E36N015057 License Plate: H-M3 AFTER CLEARING FAULTS Mileage: 189800km-117936mi Repair Order: Chassis Type: 4E (4E0) Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 18 19 1E 25 28 34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 67 72 76 77 VIN: WAUZZZ4E36N015057 Mileage: 189800km-117936miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 06-Seat Mem. Pass -- Status: Malfunction 0010 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 11-Engine II -- Status: OK 0000 31-Engine other -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 18-Aux. Heat -- Status: Malfunction 0010 19-CAN Gateway -- Status: OK 0000 1E-Media Player 2 -- Status: OK 0000 25-Immobilizer -- Status: Malfunction 0010 28-HVAC, Rear -- Status: OK 0000 34-Level Control -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 38-Roof Electronics -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 57-TV Tuner -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 67-Voice Control -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: Malfunction 0010 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 4E1 910 409 A HW: 4E1 907 409 Component: 4.2L V8TDI G000AGM™0070 Revision: --H01--- Serial number: AUX3Z0E9377335 Coding: 0011773 Shop #: WSC 00618 210 91869 VCID: 224B051DFD400F2E48-8076 1 Fault Found: 005663 - Glowplug for Cylinder 6 (Q15) P161F - 001 - Open Circuit Freeze Frame: Fault Status: 01110001 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 188030 km Time Indication: 0 Date: 2016.02.07 Time: 14:48:40 Freeze Frame: RPM: 630 /min Torque: 132.6 Nm Speed: 0.0 km/h Duty Cycle: 0.4 % Voltage: 13.83 V Duty Cycle: 24.9 % Temperature: 31.5∞C Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E1 910 156 P HW: 09E 927 156 B Component: AG6 09E 4,2lTDI RdW 0030 Revision: --H01--- Serial number: 0070253 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 306FFF55A3ACADBECE-8064 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC Component: ESP 5.7 allrad H44 0510 Coding: 0007557 Shop #: WSC 02313 000 00000 VCID: 224B051DFD400F2E48-8076 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 K Component: FBS AUDID3 H08 0160 Revision: 01604808 Serial number: AUX3Z0E9377335 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: 58BF67F5EB9C95FE66-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX 4 Faults Found: 00190 - Driver's Door Handle Touch Sensor (G415) 007 - Short to Ground Freeze Frame: Fault Status: 01100111 Fault Priority: 3 Fault Frequency: 14 Reset counter: 58 Mileage: 188000 km Time Indication: 0 Date: 2016.02.06 Time: 18:36:58 00955 - Key 1 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 4 Fault Frequency: 9 Reset counter: 80 Mileage: 188016 km Time Indication: 0 Date: 2016.02.07 Time: 14:48:08 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 8 Reset counter: 71 Mileage: 188352 km Time Indication: 0 Date: 2016.02.24 Time: 18:06:26 01176 - Key 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 2 Reset counter: 255 Mileage: 188544 km Time Indication: 0 Date: 2016.03.05 Time: 19:04:00 ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory BFS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063840 Shop #: WSC 02313 785 00200 VCID: 24470305E754011E3A-8070 1 Fault Found: 01964 - Control Module for Seat & Steering Column Memory (J136) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 2 Reset counter: 87 Mileage: 189344 km Time Indication: 0 Date: 2016.03.28 Time: 13:06:53 ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 769 E HW: 4E0 035 729 A Component: Interfacebox H43 5150 Revision: 00000000 Serial number: 300KR057560990 Coding: 0000002 Shop #: WSC 02313 785 00200 VCID: 2E53E12DB998BB4EDC-807A Subsystem 1 - Part No: 4E0 910 611 Component: E0380 BedienteilH01 0040 Subsystem 2 - Serial number: 00000000030612 Subsystem 3 - Serial number: 0106.02.070000000100010076ˇ Subsystem 4 - Serial number: 010076ˇ No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 B HW: 4E0 820 043 D Component: KLIMAAUTOMAT 016 0400 Revision: 00000030 Serial number: 00000000080247 Coding: 1136721 Shop #: WSC 02311 785 00200 VCID: 1C373BE5DF2439DE82-8048 2 Faults Found: 00066 - Rear Right Footwell Heater (Z43) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 100 Mileage: 170922 km Time Indication: 0 Date: 2014.10.12 Time: 22:47:25 Freeze Frame: Voltage: 14.00 V 00065 - Rear Left Footwell Heater (Z42) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 61 Mileage: 142775 km Time Indication: 0 Date: 2013.03.28 Time: 04:14:06 Freeze Frame: Voltage: 14.40 V ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.lbl Part No SW: 4E0 910 279 L HW: 4E0 907 279 L Component: ILM Fahrer H13 0210 Coding: 0143121 Shop #: WSC 02313 785 00200 VCID: 3169FA51A8A6A4B6C1-8064 Subsystem 1 - Part No: 4E2 910 113 B Component: Wischer WWS D3 H50 0420 Coding: 00000036 Shop #: WSC 02313 Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH10 0050 Coding: 00139548 Shop #: WSC 02313 2 Faults Found: 01520 - Rain and Light Recognition Sensor (G397) 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 20 Reset counter: 70 Mileage: 186069 km Time Indication: 0 Date: 2015.10.21 Time: 19:55:15 00908 - Control Module for Wiper Motor 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 2 Reset counter: 71 Mileage: 188665 km Time Indication: 0 Date: 2016.03.11 Time: 19:38:26 ------------------------------------------------------------------------------- Address 11: Engine II Labels: Redir Fail! Part No SW: 4E1 910 409 A HW: 4E1 907 409 Component: 4.2L V8TDI G000AGS™0070 Revision: --H01--- Serial number: AUX3Z0E9377335 Coding: 0011773 Shop #: WSC 00618 210 91869 VCID: 224B051DFD400F2E48-8076 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-94.lbl Part No SW: 4E0 910 655 D HW: 4E0 959 655 H Component: Airbag 9.41 H12 3610 Revision: 91H12360 Serial number: 0037P0009AY2 Coding: 0431707 Shop #: WSC 02313 785 00200 VCID: 275D14099662EA061F-8072 Subsystem 1 - Serial number: 63328RB400C4BDE3Z Subsystem 2 - Serial number: 63428RB400C4BD1DX Subsystem 3 - Serial number: 63528RB400C4BE0F- Subsystem 4 - Serial number: 63628RB400C4BCED4 Subsystem 5 - Serial number: 63729RB400B6A080I Subsystem 6 - Serial number: 63829RB400BE574C. No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenks‰ulenmodul H13 0040 Coding: 0112141 Shop #: WSC 02313 785 00200 VCID: 65C15E01ACEE3816ED-8030 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H07 0090 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 950 P HW: 4E0 920 950 P Component: KOMBIINSTR. VDO H71 0400 Revision: D02 Serial number: AUDID3EN000445 Coding: 0000413 Shop #: WSC 12345 001 136936 VCID: 3169FA51A8A6A4B6C1-8064 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 950 P HW: 4E0 920 950 P Component: KOMBIINSTR. VDO H71 0400 Revision: D02 Serial number: AUDID3EN000445 Coding: 0000413 Shop #: WSC 12345 001 136936 VCID: 3169FA51A8A6A4B6C1-8064 No fault code found. ------------------------------------------------------------------------------- Address 18: Aux. Heat Labels: None Part No SW: 4E0 910 105 A HW: 4E0 815 069 E Component: Heizgeraet H07 0110 Revision: 0000000C Serial number: 00000009006406 Coding: 0000001 Shop #: WSC 00000 000 00000 VCID: 1A3B3DFDD51047EE90-804E 2 Faults Found: 00664 - Fuel gauge 002 - Lower Limit Exceeded - Intermittent 02072 - Control Module for Energy Management (J644) 004 - No Signal/Communication - Intermittent ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4E0-910-468.clb Part No SW: 4E0 910 468 B HW: 4E0 907 468 E Component: Gateway H11 0090 Revision: 11 Serial number: 2000305B098159 Coding: FCFEFFDE2B7504 Shop #: WSC 02313 785 00200 VCID: 275D14099662EA061F-8072 No fault code found. ------------------------------------------------------------------------------- Address 1E: Media Player 2 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 F HW: 4E0 035 111 A Component: CD-Changer H44 0470 Revision: 00000000 Serial number: AUZ5ZBE8014054 Shop #: WSC 00000 000 00000 VCID: 1C373BE5DF2439DE82-8048 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 K Component: FBS AUDID3 H08 0160 Revision: 01604808 Serial number: AUX3Z0E9377335 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: 58BF67F5EB9C95FE66-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX XXXXXXXXXXX ELV XXXX 4 Faults Found: 00190 - Driver's Door Handle Touch Sensor (G415) 007 - Short to Ground Freeze Frame: Fault Status: 01100111 Fault Priority: 3 Fault Frequency: 14 Reset counter: 58 Mileage: 188000 km Time Indication: 0 Date: 2016.02.06 Time: 18:36:58 00955 - Key 1 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 4 Fault Frequency: 9 Reset counter: 80 Mileage: 188016 km Time Indication: 0 Date: 2016.02.07 Time: 14:48:08 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 8 Reset counter: 71 Mileage: 188352 km Time Indication: 0 Date: 2016.02.24 Time: 18:06:26 01176 - Key 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 2 Reset counter: 255 Mileage: 188544 km Time Indication: 0 Date: 2016.03.05 Time: 19:04:00 ------------------------------------------------------------------------------- Address 28: HVAC, Rear Labels: None Part No SW: 4E0 910 158 HW: 4E0 919 158 A Component: KLIMA-STG. FOND 015 0220 Revision: 00000018 Serial number: 00000000034090 Coding: 0000000 Shop #: WSC 00000 000 00000 VCID: 61C94A11B8C6543611-8034 No fault code found. ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.lbl Part No SW: 4E0 910 553 J HW: 4E0 907 553 F Component: LUFTFDR.-CDC H06 6310 Coding: 0015510 Shop #: WSC 00613 210 88222 VCID: 2A5BED3D8570D76E00-807E 2 Faults Found: 01772 - Signal from Level Control Pressure Sensor (G291) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 14 Reset counter: 100 Mileage: 188446 km Time Indication: 0 Date: 2016.03.01 Time: 20:11:47 01398 - Signal Conductor for Central Locking; Doors Open 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 5 Reset counter: 82 Mileage: 188692 km Time Indication: 0 Date: 2016.03.13 Time: 23:12:31 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory FS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063850 Shop #: WSC 02313 785 00200 VCID: 24470305E754011E3A-8070 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 P HW: 4E0 919 887 D Component: MNS ECE H46 1060 Revision: 00000000 Serial number: 364K/057506849 Shop #: WSC 02313 785 00200 VCID: 3B75D8797AEA5EE66B-806E No fault code found. ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H02 0090 Serial number: 00000528500018 Coding: 0035984 Shop #: WSC 02313 785 00200 VCID: 1D3136E1C43E30D675-8048 1 Fault Found: 00207 - Humidity Sensor Heater (N340) 006 - Short to Plus - Intermittent Freeze Frame: Fault Status: 00100110 Fault Priority: 0 Fault Frequency: 15 Reset counter: 102 Mileage: 187972 km Time Indication: 0 Date: 2016.02.06 Time: 17:52:00 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 802 B Component: T¸rsteuer.FS BRM003 0100 Coding: 0032622 Shop #: WSC 02311 785 00200 VCID: 204F0F15F34C1D3E5E-8074 1 Fault Found: 02126 - Central Locking Button; Exterior Door Handle 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 14 Reset counter: 98 Mileage: 189696 km Time Indication: 0 Date: 2016.04.05 Time: 13:35:48 ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4E0-910-289.lbl Part No SW: 4E0 910 289 B HW: 4E0 907 289 Component: Komfortgeraet H05 0010 Revision: 00100005 Serial number: W040511080555 Coding: 0004861 Shop #: WSC 02313 785 00200 VCID: 285F17359B7CE57E16-807C Subsystem 1 - Part No: 4E0 910 853 Component: Heckdeckel H06 0060 Subsystem 2 - Component: NGS keine Antwort 2 Faults Found: 00892 - Switch for Trunk Closing Cylinder (F248) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 3 Fault Frequency: 23 Reset counter: 87 Mileage: 188030 km Time Indication: 0 Date: 2016.02.07 Time: 17:14:50 02167 - Control Module for Tilt-Sensing Alarm (J529) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 254 Reset counter: 62 Mileage: 153604 km Time Indication: 0 Date: 2013.12.19 Time: 21:10:44 ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4E0-910-223.lbl Part No SW: 4E0 910 223 R HW: 4E0 035 223 G Component: DSP-High D3 H02 0120 Revision: PROD_01 Serial number: 00000000200618 Coding: 0000021 Shop #: WSC 02313 785 00200 VCID: 2C57EB258F84C95EF2-8078 No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 A Component: ILM Beifahrer H11 0070 Revision: Serial number: 00000000073177 Coding: 0010101 Shop #: WSC 02313 785 00200 VCID: 1E3331EDC9382BCE6C-804A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 801 B Component: T¸rsteuer.BF BRM003 0100 Coding: 0032622 Shop #: WSC 02311 785 00200 VCID: 204F0F15F34C1D3E5E-8074 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 C HW: 4E0 907 801 A Component: EPB A32C0220 H02 0220 Revision: A32C0220 Coding: 0001031 Shop #: WSC 00654 210 60455 VCID: 1F4D0CE9CE3222C667-804A 1 Fault Found: 02596 - Rear Brake Pads Worn 008 - Implausible Signal Freeze Frame: Fault Status: 01111000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 239 Mileage: 187928 km Time Indication: 0 Date: 2016.02.04 Time: 16:05:13 Freeze Frame: Voltage: 12.53 V Count: 61 ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 8P0-907-357.lbl Part No: 8P0 907 357 F Component: Dynamische LWR H01 0010 Revision: 00000001 Serial number: Coding: 0000006 Shop #: WSC 02313 785 00200 VCID: 3D71D66164FE50D655-8068 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 Q HW: 4E0 035 541 L Component: TUNER EU/US/RDW H42 0620 Revision: 00000000 Serial number: 304KK057611415 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 2E53E12DB998BB4EDC-807A 1 Fault Found: 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 6 Reset counter: 102 Mileage: 0 km Time Indication: 0 ------------------------------------------------------------------------------- Address 57: TV Tuner Labels: 4E0-910-146.clb Part No SW: 4E0 910 146 G HW: 4E0 919 146 C Component: TV analog TUNER H14 0300 Revision: 00000072 Serial number: 00000000021917 Coding: 0000003 Shop #: WSC 02313 785 00200 VCID: 25411E01EC6EF8162D-8070 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H12 0550 Revision: 00000000 Serial number: 00000000005041 Shop #: WSC 00947 210 62103 VCID: 204F0F15F34C1D3E5E-8074 Subsystem 1 - Part No: 4E0 915 105 A Component: von VA0 1511070713 Coding: 344530393135313035412056413031353131303730373133 Shop #: WSC 00000 128 00289 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 801 C Component: T¸rsteuer.HL BRM003 0100 Coding: 0032622 Shop #: WSC 02311 785 00200 VCID: 1E3331EDC9382BCE6C-804A No fault code found. ------------------------------------------------------------------------------- Address 67: Voice Control Labels: 4E0-910-75x-67.lbl Part No SW: 4E0 910 754 S HW: 4E0 035 753 A Component: SDS 3502 UK H45 0630 Revision: 00000000 Serial number: 00000511090356 Shop #: WSC 12336 024 394758 VCID: 3663C94D41C8838E94-8062 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 802 C Component: T¸rsteuer.HR BRM003 0100 Coding: 0032622 Shop #: WSC 02311 785 00200 VCID: 1E3331EDC9382BCE6C-804A No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 C HW: 4E0 919 283 C Component: Parkhilfe 8-Kan H12 0030 Revision: 00H12000 Serial number: 08720528502256 Coding: 0201108 Shop #: WSC 02313 785 00200 VCID: 23450019E25A062643-8076 1 Fault Found: 01628 - Sensor for Parking-Aid; Front Mid-Left (G254) 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 3 Fault Frequency: 3 Reset counter: 63 Mileage: 187972 km Time Indication: 0 Date: 2016.02.06 Time: 17:50:58 ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-333.lbl Part No SW: 4E0 910 333 F HW: 4E0 862 333 C Component: TELEFONMODUL EU 0770 Revision: 00000007 Serial number: T2AUDX0706J1VP Coding: 0000005 Shop #: WSC 02313 785 00200 VCID: 224B051DFD400F2E48-8076 No fault code found. End-------------------------(Elapsed Time: 03:35)--------------------------
. Nite Blue 3.0L SE Quattro |
Delete all the codes now you have a copy saved and see what comes back, a couple of codes are dated 2013 so it hasn't been read and cleared in a while.
Something happened on the 6th Feb this year as quite a few codes are dated then, I wouldn't worry to much yet till they have been cleared and you drive it round for a week or two and see what comes back ![]()
I bet most of the codes will clear and not come back. Maybe the ignition was on with battery off, unplugged a module with battery connected etc.
cheers guys but I have only had the car for few months so don't know past diagnostic history. I am sure marcin did reset it as the logs are prior and after?
