Go Back   A8 Parts Forum > A8 D4 > D4 - Common Faults
D4 - Common Faults Quick links to all known common faults and their solutions
Old 8th May 2016, 06:45 PM
nath nath is offline
Default d4 wiring loom issues
just noticed there is nothing whatsoever in the d4 section
for common faults ...
having read a couple of other forums im concerned about the coolant pressurisation problem which now appears to be affecting d4 vehicles
has anyone experienced this as yet ?
Old 8th May 2016, 07:15 PM
no tell more
Old 8th May 2016, 07:16 PM
Joe2.0E Joe2.0E is offline
Not sure if this is relevant but I had a coolant pump of some nature replaced under warranty last summer. My D4 is a 2011 3.0TDI with 60k miles. I wasnt aware of any issues but apparently a fault code flagged it when it was in my local Audi dealer for a software update. From memory it wasnt expensive but I'll have a look for any paperwork that might show a part number if that helps.
Old 8th May 2016, 07:50 PM
Interested in this also...... I have this logged, cleared and comes back
Code:
0378 - Coolant Circulation Pump
          B10D0 04 [009] - Internal System Fault
          Confirmed - Tested Since Memory Clear
Led me to a few threads like this http://www.audiworld.com/forums/a8-s...rness-2862459/
Due to go in under warranty in a couple of weeks
Old 8th May 2016, 08:41 PM
Could have sworn this stuff was in the common faults section like the D2 and D3 sub sections.
Anyway here it is for your reading pleasure
http://forum.a8parts.co.uk/showthread.php?t=8379
Old 8th May 2016, 09:21 PM
V059121012A is the part no. for the coolant pump replaced on my D4.
Google indicates its a small cheap looking plastic pump, no surprise it didnt last long. Not sure it does much anyway as i hadnt noticed any issue prior to replacement or any difference afterwards.
Photo attached from Garage Paperwork. Prices are in € + vat.
Old 8th May 2016, 09:32 PM
At that price not the end of the world, so long as it isn't an engine out job to fit it time wise!?
Old 23rd June 2016, 04:35 PM
damtom85 damtom85 is offline
i cant find this part as this is the pump is likely to throw fault
Audi A8 D4 4H 2012 3.0tdi Quattro 8spd ZF 8HP55a
