Old 2nd June 2016, 07:22 AM
Takemetothepub Takemetothepub is offline
Default Amp Component Protection after MMI update
Hi all, I ran the MMI updates last night and now only the left side of the speakers are working in the car.
VAGCOM says the amp is in component protection.
A little read up says dealer only can sort this out, is that true or does anyone have a trick that can fix this?
Old 2nd June 2016, 07:36 AM
some say if you run the update again it can fix it, never seen a post from an actual person who has fixed it only a rumour post so to speak
dealer is probably the way forward, charged me £23 was in the dealer for half hour at most.
Old 2nd June 2016, 07:37 AM
Thank you.
Old 2nd June 2016, 08:24 AM
If a rerun doesn't resolve it (try an MMI reset as well aka 3 finger press) then it'll require a connection back to the motherland to establish the part in CP belongs to the car
One of my local independents now has this capability and charges £15-20 IIRC. Main dealer rates can vary a lot so don't be surprised if one quotes you an hour's labour!
Old 2nd June 2016, 11:08 AM
My local Audi want £81 to do the CP reset. Oh well, not the end of the world. Thanks again.
Old 2nd June 2016, 11:13 AM
I think its a bit cheeky asking that much - If you are a regular there I would ask if they couldn't discount it a bit considering its less than half an hours work
