In, out, shake it all about...
![]() Not what I was planning to do with my Sunday, but decided it was easier to pull the whole lot than to try and get the gearbox out on its own. 4 hours drive in to engine on the floor. I'm getting too good at this ![]() Copper-coated exhaust nuts do *not* like stainless steel bolts. Several of them on the downpipes have seized already after only 300 miles so I'll be replacing those with stainless locknuts. The gearbox is leaking from the shifter spindle. I think that seal can be changed without cracking it open. I hope so anyway! Its also leaking from the passenger side output flange, which I didn't change the first time round since you have to press the shaft out of the bearing on that side. I guess I'll do that while its out. I'll split the engine and gearbox this afternoon and hopefully the replacement TC will arrive in a couple of days so I can put it back together next week. |
You ARE getting good at that! Well, the weather is cr@p so you may as well do something useful on a Sunday.
Yeah I just mowed the lawn....
Its been 27* here. I would much rather have gone sailing
![]() The irony is, this is guaranteed not to be the last time this lot comes out, since even if the new TC solves the immediate problem there is a manual conversion to come once I've collected all the bits. If I have to take it out every 300 miles though, I shan't be amused! Took the engine off the gearbox this time - much easier than taking the gearbox off the engine since the engine is pretty stable but the gearbox has a weird centre of gravity which makes it very hard to balance. Propped the 'box up on a pallet and strapped the engine to the crane then just rolled the crane away. Simples ![]() ![]() Looks like the shifter shaft has to come out to get the seal out so that's staying put. The output shaft bearing is a standard off-the-shelf part though (6007 C3 for future reference), as is the oil seal. £13 for the pair from Simply Bearings instead of £50 from Audi ![]() Last edited by MikkiJayne; 17th July 2016 at 06:11 PM. |
Hell, Mickki, I was contemplating how difficult it would be to remove the manifold to spay paint it (there's some flaky paint) and was put off by the removal of the injection system..... and you pull the guts out of the car in 4 hrs.
The main thing to be careful of when working on the inlet manifold is dirt and grit dropping in to the ports. These engines tend to collect it in all the nooks and crannies around that area so its a good idea to vacuum as much as you can out of there (use a short bit of garden hose duct-taped to your hoover tubes) and then if you can, blast it with a bit of compressed air to make sure its all clean.
Then if you squirt a bit of WD40 at the base of each injector it makes it a lot easier to lift the fuel rail out complete with all the injectors. It'll take some persuading but it'll come eventually. There are some pics on Audiworld of the S8 manifold in bits iirc but I can't find them. Its best to just take the top off and leave the rest in place as. Trying to take the whole thing off is quite complex as you've got all the gubbins around the throttle body to deal with. ![]() |
