Old 26th July 2016, 02:15 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Default AC Fault
I had a mobile AC guy come to work to put some gas in my AC but before he gases it he does a diagnostic on the AC to make sure its not a waste of our time.
He went through the normal leak test and so on. It passed all of those test but when it came to testing the pump (turning it on), the pump never kicked in.
Checked for fault codes and nothing.
The guy said it could be a relay or a pump but we need to test them.
Anyone got any tips or advice on the best way to check the pump and relay and the location of the AC relay, is it an relay?
[center]
06 3.0TDI Quattro:
Options:
Old 26th July 2016, 02:50 PM
I had mine done last year, it failed the leak test. However nearly two years on the AC is still working perfectly.
I am sure there would be fault codes for relay or the pump.
Old 26th July 2016, 05:18 PM
Dis you check for codes with VCDS, or did the AC man use something that they may not have shown up with. If it's not working, I'm sure there would be a fault in HVAC.
In VCDS> HVAC look in Supp. Codes to see what error codes are available to get an idea how comprehensive they are.
Old 26th July 2016, 05:23 PM
ScottD3's Avatar
The guy used VCDS.
Only fault codes the low pressure fault which means no or low gas.
He put his gas in when testing for leaks and the fault code went away and never came back.
There was no other codes.
He had to drain the system when he went away.
I'm going to pop out tomorrow to see if I can get gassed up and do some more fault finding.
Not sure what.
[center]
06 3.0TDI Quattro:
Options:
Old 26th July 2016, 06:22 PM
Compressor should be running all the time on D3, not like the old cars with electric clutch so there will be no relay. There is just a solenoid valve that controls pressure and cooling dynamically rather than old style on/off and is more efficient way. My friend with A4 have been told similar thing like you by AC guy and told him AC compressor needs to be replaced at great cost.
I had a quick look, recommended him to replace pressure sensor, 35 mile drive later to closest Audi dealer who had 1 in stock, about £50 and 10 minutes later everything was working as it should. On the plus side he got free gas recharge as the AC guy did not take any money from him as it was not working after filling up.
Old 26th July 2016, 07:11 PM
ScottD3's Avatar
Fitted a new pressure switch.
If it's constantly on, it's sounding more and more like a pump.
[center]
06 3.0TDI Quattro:
Options:
