Old 26th July 2016, 04:50 PM
Default Replacing rubber boot seal.
Yes, I know technically it's not outside, but then it's not inside either....
My boot seal is badly damaged, from luggage being dragged in and out (not be me, it arrived like that). So I bought a spare from our sponsors when the new shop was offering a massive discount.
It's pretty obvious which bits of trim have to come off, only the big one along the sill (with the light in) looks vaguely non-trivial.
BUT, are there any other considerations, e.g. is it just a push-fit or is there adhesive to overcome, in which case would heat (hairdryer or similar) help with removal.
And are there any tricks to getting the replacement back on? It looks like the "join" is half-way down the left side in both old and new.
The "new" one does have some minor damage, but nothing comparable to the old one which is rather beyond redemption. And as a sometime cyclist used to "rubber repairs" it's nothing I can't deal with.
Old 26th July 2016, 07:34 PM
It's just a push fit with clips, from memory. Push towards boot to release about 4 plastic push in clips (once you've removed the 2 black circular clips where the centres pull out and the outer bit kind of wiggles out!)
The side bits Velcro'd to sides of boot need to come off first
Not near car but don't remember it being awkward to get out
Old 26th July 2016, 08:20 PM
Adrian, I mean the tubular rubber seal that goes all the way round the boot opening, worried about glue or other hidden fixings.
The trim bits I'm OK with I think. Been in and around there a fair few times.
Old 27th July 2016, 12:43 PM
Ah sorry, read it that you weren't sure how that bit came out!
Doesn't the replacement part help with establishing fixing points, if any?
Old 28th July 2016, 07:39 AM
It is simple push fit. Make sure vulcanised seam is aligned with left side ball hinge that holds boot strut. Check position of the seam before removing the old seal.
Old 28th July 2016, 08:47 AM
Thanks, I had noticed that alignment and planned to copy it. Any logical reason you know of for that?
