Old 6th August 2016, 05:31 PM
milo900 milo900 is offline
Default Serpentine tensioner
Hi, new to the forum, just got myself an s8 d2. In the process of doing the timing belt, water pump and thermostat. Got those bits but need a serpentine belt tensioner. I've checked out the usual places but they don't seem to do them. Any idea where best to get one?
Old 6th August 2016, 07:07 PM
Are you doing all the idler pulleys and rollers? Do you mean the "Tensioning Lever" (aka "Clamping Lever") or the "Eccentric Adjuster"? I got all OEM parts ordered by my indy mechanic who got them thru TPS.
Old 6th August 2016, 07:54 PM
There's a Febi Bilstein one here: http://www.ebay.co.uk/itm/FEBI-BILST...4AAOSwuhhXUVMG
If you have a friendly mechanic with a TPS account then it's worth getting a price on a genuine one: 077903133E
The roller is the same as on a 2.7 Hyundai engine if the tensioner part is still ok.
Old 6th August 2016, 08:55 PM
Not sure thats the correct one Mikki? The photo shows all the parts and their numbers taken from my D2 S8 and part and number are different. The part names show the names as taken from ETKA which uses different terms in different diagrams and text!!
Name:	Timing belt +rollers_pulleys_tensioners.JPG
Old 6th August 2016, 10:09 PM
Serpentine belt is the accessory poly-v belt, not the toothed timing belt
The tensioner is this beastie:
Old 7th August 2016, 11:34 AM
Yeah thanks guys. Its the v belt tensioner I'm after, managed to sort out the timing belt kit. The eBay one looks the best bet, thanks.
Also, with regards the timing belt, got the new belt on and rotated the engine over a couple of turns but the belt if loose on the lower right side. I've read a few of the guides and they seem to have slightly different ways of doing the job.
I'm guessing I need to adjust the tensioner pulley right side?
Any advise would be great.
Old 7th August 2016, 01:41 PM
Ahh, this is always a problem when referring to parts by such terms- even if that whats its called in ETKA! The toothed timing belt is certainly serpentine in the true sense of the word!
