Go Back   A8 Parts Forum > A8 D4 > D4 - Lights
D4 - Lights Headlights, xenons, foglights. Everything outside the car that glows
Old 23rd August 2016, 05:27 PM
nath nath is offline
Default headlamp cornering light fault
hi guys
dont know if anyone has come across the fault before
Address 55: Headlight Range Labels: 4H4-907-357-V1.clb
Control Module Part Number: 4H4 907 357 HW: 4H4 907 357
Component and/or Version: ....AFS13.... H01 0055
Software Coding: 11116F33F918EA00
Work Shop Code: WSC 02313 785 00200
ASAM Dataset: EV_AdvanFrontSyste 005001 (AU64)
ROD: EV_AdvanFrontSyste_AU21.rod
VCID: 6FEBEFB8B6964F3A49-803A
1 Fault Found:
572427 - Stationary Cornering Lamp Right
C1084 13 [137] - Open Circuit
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 110
Mileage: 104234 km
Date: 2016.08.23
Time: 17:09:01
Tuesday,23,August,2016,17:34:58:02883
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 16.8.0.3 (x64)
Data version: 20160803 DS255
www.Ross-Tech.com
any ideas would be good cheers guys
Old 23rd August 2016, 06:13 PM
Pug Pug is offline
Open circuit could be anything from a broken wire to a blown bulb?
Current: MY2019.5 Ford Ranger Wildtrak 2.0 BiTurbo
A8/S8 - A gap to fill.
Multi-Franchise Main Dealer during the day, Amateur vehicle enthusiast by night.
Old 23rd August 2016, 07:33 PM
thanks
the vehicle comes up with an adaptive light fault when its dark only
(lights are set to auto)
is the adaptive light part of the headlight or is it part of the fog lights ???
cant get my front fog lights to come on at all
in auto or manual
Old 23rd August 2016, 08:09 PM
Pug Pug is offline
Usually the cornering light is a bulb situated at an angle between the projector for the dipped beam and the DRL.
Couldn't really comment on the fog lights. All seems very odd.
Old 24th August 2016, 08:07 AM
Conquistador's Avatar
This may help:
The adaptive cornering light is the one sticking out at an angle and you can see it working at night by turning the wheel each way when you're stationary. Fog lights are just fog lights, they won't come on automatically under any circumstances.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 26th August 2016, 10:53 AM
sorted it thanks guys
after checking the multiple fuses for the headlights
i removed the headlight itself and found a blown bulb on the drivers side
replaced it and still nothing
checked passenger side and that was ok
went back into vcds and cleared the fault and everything started to work again
so all sorted thanks
