Old 29th August 2016, 11:32 AM
Lee S Lee S is offline
Default What on earth ?!?!?
Was just having a poke around the engine bay on my car and decided to remove the scuttle trim to have a quick check and make sure the leaves hadn't filled it up completely when I noticed this thing...
Doesn't really look OEM and looks like it has been added afterwards. Stuck to the top of the ECU with sticky foam or Velcro and a cable/s going off down into a grommet that looks like it has been pierced and then some kind of silicon or mastic added. Looks like a GPS tag or sensor or something.
So questions....
a) any idea whet the hell it is?
b) is it OEM or something aftermarket?
Had the car remapped at MRC and they never mentioned anything but I noticed they had the same scuttle trim off to plug into the ECU I guess.
Are there any ELSA diagrams that show this thing??
ID:	14076   Click image for larger version
Lee
2017 Nissan Leaf Tekna
Old 29th August 2016, 12:06 PM
Looks like an aftermarket GPS antenna and thin coax cable.
Usually for dashcams, taximeters, trackers.
Back in the day when our cars were new, GPS stuff tended to have these external antennas rather than the tiny in-built ones brought about by the smartphone revoltion.
Old 29th August 2016, 12:21 PM
Definitely.
Maybe the boot antenna packed up and this was their way of supplying the signal?
I had to do this on my PF S8 but mounted it outside at the base of the rear window.
Old 29th August 2016, 01:10 PM
Very odd. Maybe I will try and trace where the cable goes. Not sure I like the idea of it being there unless it has been fitted to replace the existing aerial. I will clean it up and see if there are any model or makers numbers on it.
When I had the rear screen done in March or whenever it was, they reckoned it had been out before so I wonder if the proper antennas had been damaged or the wiring damaged. GPS and sat navigation all seems to work fine and there are no VCDS errors or anything.
If it does need to be there I may do a better job of sealing the grommet. Doesn't seem to be sealing the cable very well. Wonder if moisture has been getting in by running down the cable.
The whole bizarre thing is why anyone would have bodged anything like this on a car of such value that was only 18 months to 3 years old?!? It beggars belief and annoys me. I hate bodgers.... If you're gonna do a job, do it properly and if you can't afford to do it properly then you shouldn't own such a car... Grrrr
Lee
Old 29th August 2016, 01:21 PM
Johnmed's Avatar
Johnmed Johnmed is offline
I fit these to everyone's car I do work on. Then I sit stroking a white cat, watching where everyone is on my laptop.
Muhahahahah.
2007 Mini Cooper S R56
Old 1st September 2016, 05:28 AM
Artermis Artermis is offline
I agree with above - that is trademark GPS receiver looking 'brick'. I've come across them plenty of times as they're the RX of choice for after market navigation head units. Typically I've usually left them internal at the bottom of the windscreen or similar out of view, so long as it's got a clear view of the sky it will work.
One thing I would say is they often have a magnetic base on them, hopefully this one doesn't being stuck down with sticky, but if it does have a magnet I wouldn't have wanted it stuck to the ECU!
Current: 2004 D3 4.0 TDI V8 in Crystal Blue.
Factory: finger print, tv, xenons, keyless entry & go, soft close boot, 19s, and probably lots more besides
Done: fixed headlight washer leak, fit Bluetooth in place of factory phone
To do: DAB, DTV, fix soft close boot, get a spare key, investigate NSF bushes,
