Old 15th September 2016, 09:56 PM
Lightbulb S8 V10 Flaps Delete (Intake Manifold)
Here it is, for everyone who suffers or may suffer in the future from a broken intake manifold flap/s.
This is an alternative to couple of £k manifold or a repair (£250) which I was going to do by sending the manifold to an engineer Ron knows, but decided nlt to purely as he couldn't provide any pictures of the repair so I can see how well this is done.
And this was the reason for it, one flap broken of laying at the bottom of the manifold and second one hanging up in the air.
Oil separator was faulty hence a bit more than usual of filth inside the manifold.
Prons:
- more engine growl
- louder exhaust
- BHP gain at the higher revs
- huge satisfaction from doing it yourself
Cons:
- slight loss of BHP at the very low end of revs, but not noticeable on this powerful engine. After talking to remap place this loss can be easily recovered with the remap on the dyno which is my next step but also you will double gain BHP on the higher revs.
I followed this guide in order to remove the manifold.
http://audirevolution.net/forum/index.php?topic=3221.0
Please note:
- Inlet wont come out just like that like this guy claims
- You will have to remove both fuel pumps, one on each side of the manifold
- Remove two the most obvious and easiest to undo fuel lines and move them aside.
- This is the worst part which he did not mention at all, unless someone had his manifold out before and did not bother to bolt on the electrical connectors bracket for the fuel injectors which is bolted by two torx bolts to the bottom/front manifold and which will prevent you from removing the manifold.
You WILL NEED a pair or small hands, lots of patience and this mini ratchet with a torx bit (T25 or T30) on the end to unbolt the bracket. This is one of them bolts I've dropped and recover using endoscope camera and grap tool. Both bolts are visible thru the square cut out with the pin in the middle of the crash frame where the bonnet's latch goes.
http://www.screwfix.com/p/titan-scre...questid=550707
Now, this is where it gets interesting as manifold is made from a tough mix on magnesium, zink and aluminium which is also fragile to chips/possibly even cracks when you try to lever it while splitting to hard. That is mainly due to the silicon gasket being very very strong which was applied at the factory not only around the edge but also around each inlet and internal ribs for each intake channel.
Patience, patience, lots of patience, swearing in between and sweat running down your back.
First attempts on the bench where a complete failure even with my mate giving me a hand so time came for attempt no. 2, screwing the manifold to a pallet I quickly made for the engine which fits under my engine hoist. This was the way to go.
Tools:
- Torx bit
- heat gun
- thin ish but as wide as possible flat head screwdriver (worth thinning the end off slightly with a grinder)
- stanley knife
- WD40 Specialist Fast Acting Degreaser (for decoking/cleaning the inlet channels and variable inlet flaps) together with few green scouring pads
- 2-3 packs of plastic spudgers for removing the silicon from the grooves
http://www.ebay.co.uk/itm/3-X-PCS-PL...EAAOSw6btXRmwk
- couple of small brass wire brushes for removing fine pieces of silicon seal left behind and final preparation of surface for resealing (it's much harder with the big brushes)
https://www.amazon.co.uk/175MM-BRUSH...wire+brush+set
Splitting is the worst part so as soon this task is done rest is just a time consuming job.
Front right corner is the best place to start as the ridge/grove which is all round the manifold is only set back 2-3mm from the edge and this particular corner and front of the manifold has approx 8-10mm of flat surface before the ridge.
You will only be able lift a tiny section, cut only some of the seal and when you get as far as approx. 1/3 of the way down the side its worth lifting the corner again and wedging and leaving a second screwdriver.
Don't know if that helped much, but I was heating up the manifold from the inside by blowing high temp down the whole where the T piece is bold on.
I only done once and for the first time in my life so can't give you a better advice unfortunately. I haven't seen anyone splitting it before either, but all I can say its doable without damaging it
There are 26x torx bolts you will have to undo, 10x at the top around the edges and 16x from the bottom
Here is the manifold with the bottom part removed.
All the black/grey stuff around each groove is the silicon gasket, there is plenty of it around to be removed.
You can also see how the exits to each inlet on the engine are coked up as well (part I mentioned in the decoke thread which really pushed me into decoking the whole engine)
Few shots of the flaps
Flaps removed, actuator motors removed and manifold ready for cleaning.
One row of flaps was in very good condition while the other driven by the main set was absolutely worn out damaged in multiple places which makes no sense as you would expect the main set to be ruined which is driven the by actuator motor mounted at the front of the manifold.
Breaking off them ain't very easy, a strong flat head screwdriver with thin end is needed along with the hammer to break off three plastic rivets on each flap. You can see how some holes are worn out there where the flaps got loose before detaching from the base.
As mentioned earlier removing the silicon is a real pain and here are some shots of all the sealed are preped for sealing, all the inlets along with variable flaps cleaned/decoked and both parts of the manifold drying out in the sun after last and final rinse with the WD40 Degreaser.
For sealing the manifold I've used JB Weld Ultimate Grey Silicon
Very very hard to squeeze out so expect some rushing, sweating and your hands hurting at the end as hell.
I followed the instructions by hand tightening all the bolts first, leaving the silicon to set for half an hour and then doing all the bolts up by further quarter/half a turn using a torque wrench.
I got 4 tubes, used only 2, but there was more than half left in each left.
What could help is probably warming the tubes up in a bowl with very hot water.
And here is the middle part bolted on and bottom and top part finally sealed.
All actuators bolted back on (had one arm securing clips missing from the back on one of them so decided to pop in to Audi and order and replace all 3 of them).
All the excess of the silicon from outside trimmed.
DONE !!!
Very pleased with the job and result
ID:	14390   Click image for larger version
ID:	14391   Click image for larger version
ID:	14392   Click image for larger version
ID:	14393   Click image for larger version
ID:	14394   Click image for larger version
ID:	14395   Click image for larger version
ID:	14396   Click image for larger version
ID:	14397   Click image for larger version
ID:	14398   Click image for larger version
ID:	14400   Click image for larger version
ID:	14401   Click image for larger version
ID:	14402   Click image for larger version
ID:	14403   Click image for larger version
ID:	14404   Click image for larger version
ID:	14405   Click image for larger version
ID:	14406   Click image for larger version
ID:	14407   Click image for larger version
ID:	14408   Click image for larger version
ID:	14410   Click image for larger version
ID:	14411   Click image for larger version
ID:	14412   Click image for larger version
ID:	14413   Click image for larger version
ID:	14414   Click image for larger version
ID:	14415   Click image for larger version
ID:	14416   Click image for larger version
ID:	14417   Click image for larger version
ID:	14418   Click image for larger version
ID:	14420   Click image for larger version
ID:	14421   Click image for larger version
ID:	14422   Click image for larger version
ID:	14423   Click image for larger version
ID:	14424   Click image for larger version
ID:	14425   Click image for larger version
ID:	14426   Click image for larger version
ID:	14427   Click image for larger version
ID:	14428   Click image for larger version
Old 16th September 2016, 05:21 AM
Artermis Artermis is offline
Very well done mate - I think you should be rightly proud of that one. Removing manifolds is not always a job for the fainted hearted but having a guide available will certainly make the job much, much easier for many and is a sound alternative given the cost of garage and replacement. Good work.
I think as you suggest, the minor loss of low end BHP or torque on a 5.2 V10 is going to be negligible, especially when offset against the cost and/or risk of a broken failing manifold.
Current: 2004 D3 4.0 TDI V8 in Crystal Blue.
Factory: finger print, tv, xenons, keyless entry & go, soft close boot, 19s, and probably lots more besides
Done: fixed headlight washer leak, fit Bluetooth in place of factory phone
To do: DAB, DTV, fix soft close boot, get a spare key, investigate NSF bushes,
Old 16th September 2016, 06:12 AM
Thank you very much
It was certainly a great thing to do for many reasons and satisfaction from doing it was and still is huge.
£250 repair seems a very good deal, but I only was 95% confident in it due to lack of pictures of the repair and this was the crucial 5% of me no, let's crack on with it and see what's is all about. On the end of the day if would have failed have way thru I could always sent a split manifold for the repair, but I knew from the beginning that the biggest challenge will be to split it, and it was.
I know that Ron is very pleased with his repaired manifold, but me being me and brutally honest, I've got slightly more doubts now in the repair process for such a small money considering what really is involved and how time consuming this process is. As a business I would probably charge at least £250 just for splitting the manifold and re-sealing it.
All in I'm very pleased and that loss of power if any isn't noticeable at all, when you floor it car responds the same way it was before with no weird lag or choking.
Old 16th September 2016, 08:21 AM
Norretal's Avatar
Norretal Norretal is offline
Fantastic job Marcin, and an excellent write up too
My lack of photos probably did you a favour, now you've "been there, done that" yourself, and probably have a much better understanding because of it. It's over two years now since my saga and I was very much at the mercy of those who had the car. One garage, Swift Motorsport, a local VAG independent specialist diagnosed the fault and stripped and cleaned the manifold (I witnessed it stripped down and cleaned when they showed me the failed flap) and the engineer carried out the repair for them after I was directed to him by someone who knew he'd done similar work previously. Even TPS helped me out by being incompetent as I was resigned to buying a new manifold and would have done had they been able to deliver, but that's another story.
I'm sure this will give others the satisfaction that preventative maintenance can be done to prevent failure, and even if failure comes it's not the end of the world. At the time of my drama all I could find were examples of them failing and causing engine damage and after seven weeks I was just glad to get the car back running as it should, as you can imagine.
This great forum, and the many knowledgeable people on it never fail to deliver, great work
Audi TT - 2015 - Ultra
Old 16th September 2016, 12:41 PM
Awesome write-up with lots of detail thanks for all the trouble you've gone to to write these up Marcin - added to sticky!
Old 17th September 2016, 03:57 PM
Superb post, well done for taking time to post up
