Old 18th September 2016, 12:37 PM
Seamaster Seamaster is offline
Default 4.2 TDI glow plug brand?
Hi,
Does anybody know the standard brand/type of the original equipment glow-plugs on D3 A8 4.2TDI 2007 model?
Thanks in advance
Mike
Old 18th September 2016, 01:17 PM
Pretty sure it's Bosch, but other diesel owners should be around soon to confirm it
Old 18th September 2016, 02:51 PM
Thanks for reply I am swaying to Bosch to but read somewhere that I can't find right now, that if you remove the connector you can see one of two colours at top of plug if I remember right either red or black for different types.
Codes are showing that I need a new number 7.
Mike
Old 18th September 2016, 04:18 PM
The ceramic ones were BOSCH and a disaster and production change replaced with conventional metal BERU plugs. This was a few years before your car was made so I'm sure not ceramic. The ceramic had a white band and metal had a terracotta coloured band but some aftermarket have a black band. It is of importance because the two types are different volatge and so the ECU needs coding to avoid inoperable or blown glowplug.
I would just stick with BERU. I fitted NGK but if I would just get BERU if doing again as they were 2mm shorter.
http://beru.federalmogul.com/en-gb/e-catalogue/vehicle
Attachment 14443
Old 18th September 2016, 09:28 PM
Thanks,
For the detailed info SD
Beru was the other make going through my mind.
On order.
Thanks
Mike
Old 21st September 2016, 12:12 AM
H-M3 H-M3 is offline
Originally Posted by Seamaster View Post
Thanks,
On order.
Thanks
Mike
Ps let me know how you get along with the change as I was told that they can be a pig to replace.
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
