My nearside tweeter seems to have a mind of it's own.
When I unlock the car, it rises. Sometimes all the way, sometimes part way. When the MMI is turned on, it then goes through a full cycle of movement. If unlocking left it open, it will be closed. If it was open a quarter way, it will fully open, then retract a quarter. The mechanism itself seems OK (although it does stop briefly, which tells me it's got a broken tooth) but it's getting a signal from somewhere that tells it to rise and retract. Where does the signal come from? What controls it? Any suggestions to a fix? |
The actual signal would come from MMI.
Have you scanned it for faults Tony?
Yes, I've scanned it but it only shows a mechanical fault on the tweeter. I think that may be caused by me holding down the tweeter to get it to reset itself.
Not sure if holding it down was a good idea unless that's what manual says.
I don't think it's anything to do with signal so your next step is to remove it, strip it and investigate. It will be most likely a small toothed wheel like on MMI screens which fail too.
Seems like a new tweeter from this post depends on how many tooth you have broken, if it's only one then repositioning the broken gear can solve the problem.
http://www.audiworld.com/forums/a8-s...n-but-2882401/
My guess (based on nothing!) is that with a broken tooth the system is uncertain of its position and so tries to re-set it to the correct position for the system state when, for instance, opening the door, switching on MMI etc.
