suffering from a vibration when the brakes have warmed up I am considering having the front discs skimmed on car as they look rather tatty rather than worn , so don't want to fit new pads on them
haven't yet got a quote for this but I presume it is cheaper and easier than a couple of new discs at £100 plus anyone done this ? ps to conan ...have you go 2 dictionaries in your library , one of which says axle and the other axel ...or are you an ice skater ? |
Yep, I had that done two or three years ago and it cured a long-running problem with juddering brakes.
I kept getting discs and pads replaced, but after around 1500 miles (IIRC) the juddering would come back, until the on-car skimming cured the problem.
I've had it done a couple of times (at about £50 per wheel, if I recall correctly). The juddering went away but only temporarily. Came back each time after 1000-2000 miles.
The third time the judder came back, I had the calipers inspected and had the discs and pads changed again, this time insisting on genuine OEM (the previous set were supposed to be genuine, but we couldn't be certain). Also, I decided to (attempt to) properly bed the brakes in this time, though through a lack of suitable safe brake bedding-in locations I may not have done it as thoroughly as a should. After probably 4000 miles or so some judder has returned but so far it's only very slight. I think I may be causing the problem myself somewhat by holding the brakes on while stationary following some spirited driving/braking. Traffic conditions allowing, I usually try to stay off the brake pedal or keep the car rolling a little while the discs are still hot but of course that's not always practical/possible to do.
thanks jim , will give it a go then once I have checked the discs are well above the minimum thickness which I believe is 28mm
looking at the service records the car had new jurid discs and pads fitted about 30 k ago , the pads are only about half worn ! what did the skimming cost ? any memory ? I seem to remember that you do a fair mileage so sounds economic if it has already done 2/3 years |
I can't remember the cost - I'll see if I can find a receipt
thanks mark as well , you clearly posted as I was answering jim and I didn't see it
strange the difference between your experience and jim's ; have read elsewhere that this is a problem on big powerful cars I wonder if your idea about keeping your foot on the brake could be the reason , must try slipping it into park when stopping even briefly , mine lurches a bit when I~ do that , always presumed that was normal just like on my landie on the transmission brake I suppose using the handbrake would be a good idea but it isn't exactly convenient ! Last edited by oldnick; 20th September 2016 at 01:52 PM. |
I guess it's not helped that our cars are automatic so there is a tendency to stop with the footbrake on, other than putting it in park or neutral (with handbrake on) there probably isn't much else to do.
Cars... '93 Audi Coupe 2.0 Alpine White (sold) '99 Audi S4 Merlin Purple - K04 upgrade to 412hp (sold) '00 Audi S8 Agate Grey (Sold ![]() '11 Audi Q7 4.2tdi Unknown Red (Classic Red Pearl Effect - thanks MJ) |
