Old 15th November 2016, 02:30 PM
johnny_quattro's Avatar
Default Replacing front seats
I've got the standard 'comfort' seats in my A8L FL, and the driver's seat seems to have a hotspot that I'm convinced you could cook sausages on, or in the real world, my left thigh. I'm looking to replace them with the 'sports' seats or Recaros - see attached pic of intended purchase. Is there anything I should know about before attempting this job? In particular, is the wiring loom already present and correct for the transplant to take place... I've seen a good quality and good condition set of the Recaros on FleaBay and wanted to check with you knowledgable people first.
Name:	Screenshot from 2016-11-15 15:40:07.png
Old 15th November 2016, 05:09 PM
It's a straight swap. The only possible difference is a PF / FL swap. PF cars didn't have airbags in the seat so if you put PF seats into a FL then the will be a couple of wires spare. Viva versa your short a couple of wires. HTHs.
Old 15th November 2016, 06:00 PM
Buy them quick!
Old 17th November 2016, 01:43 PM
Default Thanks
Nice work, chaps. I shall approach the vendor at my earliest convenience and hand over the cash. They came from a 2000 A8 V6, so they should obviously be from a facelift model.
Thanks again.
Old 23rd November 2016, 02:53 AM
Daz 70 Daz 70 is offline
Default Airbags
early PF cars didn't have airbags in the seats.... but late PF did... I believe this was standard from 97 (before FL). Early seats (stand, not sure about sports etc) had airbag tags on the piping at the edge of the seats while later cars hard it kinda embossed on the seats... Hope it helps...
Old 23rd November 2016, 01:38 PM
There is also a change in later cars to include a footwell courteousy light for rear passengers built into the underneath of the front seat, but its trivial and wouldn't be the end of the world.
Seat memory is something to bear in mind. Memory was standard on sports seats (drivers) but optional on other.
The bigger battle you might have is to change the rear seat. Obviously you were going to change the rear ones so it doesn't look really odd right ?
The long wheel base model you say you have has a slightly more reclined rear seat, which means the screen holes won't line up properly when you try and fit the rear seats in. I did (with some drilling and swearing) get a set of long wheel base seats into a SWB, so the opposite ought to be true.
Rear seats on LWB may also have heating and electric headrest retract which may not be on the donor sport seats.
Watch out for the wires in the rear armrest for the media control that need transplanting across too.
Enjoy
