Old 20th November 2016, 06:54 PM
Default Illuminated external door handles
As far as I know this was never an option on any D2, but I could be wrong.
Has anyone ever though about retrofitting it, presumably linked in to the interior lighting in some way?
Not sure how I would approach it, but probably with fibre optics piping the light from a source in the B pillar into the doors and handles.
Old 20th November 2016, 08:59 PM
Do you mean to illuminate the handle-well so you can see it at night? I don't see why you couldn't wire some small LEDs in to the mechanism tbh. Optical fibre might not handle the movement of the handle too well, but a couple of tiny surface-mount LEDs wouldn't be too intrusive.
You could trigger it from the interior light I think - that comes on when you unlock the car doesn't it?
Might be a nice touch
Old 20th November 2016, 09:18 PM
Exactly, linked to interior light. That's my thinking.
The light would be fixed, illuminating the handle from behind to easily find it at night.
I'm thinking fibre would be easy as for lighting it doesn't need to be very well coupled. So a single fixed LED source (each side) probably near the B-pillar (so dead easy to wire in) could be coupled across into the doors with a tiny air gap (when closed).
Saves running any electrical cables into the doors. And easy to weatherproof.
Old 20th November 2016, 09:52 PM
Oh I see what you mean. Interesting idea.
If you fitted in to the lower handle casing so it didn't move you could heat up a plastic fibre and bend it to shape.
I'm wondering about some logic where if the doors are shut you can hijack the puddle lights signal to power an LED, then you don't need any extra wires. Just a relay or two, and maybe some diodes. Hmm...
Old 20th November 2016, 09:58 PM
The problem I see with the puddle lights is that I presume they are linked to the footwell lights, so only illuminate when that specific door is opened.
Old 21st November 2016, 08:12 AM
Hence relays and diodes
With the doors shut a relay diverts the puddle light supply to the door handle (done in the door). Inside the car, with the door shut, an unlock signal which turns on the interior light also turns on all the puddle lights, but with the doors shut that lights up the handles.
