Old 4th January 2017, 03:20 PM
JamesF JamesF is offline
Default VCDS help with headlights.
Hi, I've had the dreaded adaptive light warning come and go fo the last year or so.
It's now on and won't clear so I've bought a replacement head light unit.
I wondered if there's anyone in or around Gloucestershire who might help me code the new unit and set up the headlights as they've been adjusted manually.
Old 4th January 2017, 03:38 PM
Hi James
Is it a D3??
If you have VCDS then it is very simple to code it and adjust it.
Have you replaced the headlight already??
Sometimes is just an electric motor which needs replacing inside the headlight.
Old 4th January 2017, 03:46 PM
Hi, yes I have a 2009 d3 but unfortunately I don't have vcds.
I've been using a friends snap on Modis,a great bit of kit but I've no idea how to get into program mode. They work mostly on hgv and aren't too keen to have a play setting up my car.
Old 4th January 2017, 03:48 PM
Sorry I just read the rest of your post.
The fault is motor down to earth.
Old 4th January 2017, 04:16 PM
OK, cool.
Have you replaced the headlight already ??
It could be wiring or the motor, sometimes AFS module on the side of the headlight, no need to change the headlight straight away.
I actually have one brand new headlight motor at home but it was for AFS I headlights. Not sure is AFS II (yours) is using two motors or still one but a different type with X and Y movement.
You do know that front bumper needs to come out in order to swap the headlight? Even to swap the motor/check wiring sometimes is better to do it as well for better access depending on what engine you have in there.
I would strongly recommend you getting VCDS or at least do the job using VCDS or VAS.
Old 4th January 2017, 04:20 PM
...and this is a real bargain for you
Grab it while you can
http://forum.a8parts.co.uk/showthread.php?t=12504
Old 4th January 2017, 04:39 PM
No I've not fitted the headlight yet.
It was only last year I had the bumper off to replace the ac pressure solenoid so that's not too bad.
I'm not sure what lights I have but they have led lights nearest to the grill!. I'll have to look at buying vcds,maybe I've just been lucky so far with no real problems.
