Go Back   A8 Parts Forum > A8 D4 > D4 - Lights
D4 - Lights Headlights, xenons, foglights. Everything outside the car that glows
Old 12th January 2017, 05:53 AM
Markr Markr is offline
Default Matrix Beam System Failure
System has failed on car, not a bulb failure, but feels like camera/sensor failure, as main beam still works.
Seems to be working fine on passenger side, as can still see the blackout working on that side, but not driver side, as took a few flashes from other cars to work out they were flashing me.
Waiting for my local dealer to book me in with a decent loaner, as feedback is they might have it a while as sounds like a strange one and their first Matrix Beam failure.
Will let you know how it goes.
Mark.
Old 12th January 2017, 07:53 AM
I was looking at buying D4 S8 for the past two days and all with Matrix so it will be very interesting to find out what went wrong especially if there is no faults.
This is probably a very silly question, but have you checked if camera/sensor isn't just very dirty or came loose and its pointing wrong direction ??
Have of got a VCDS to plug it in and scan for faults?
Old 12th January 2017, 07:57 AM
Joe2.0E Joe2.0E is offline
Some similar issues with A7's it would seem and not all Dealers have the specialist equipment, this could be why your dealer is putting you off for a few days.
Fantastic light output from them, I had them on a loaner A6 for a few days, make bi-xenons look like candles.
http://www.vwaudiforum.co.uk/forum/a.../t-171534.html
Old 12th January 2017, 10:05 AM
Conquistador's Avatar
I'd definitely try and scan it yourself if you have access to VCDS or there's a friendly forum member nearby with it. At least then you can hopefully get an idea of what the issue is yourself. Essex Audi for example, only have one ACC calibration/alignment unit which is taken to and from the various dealers in the group as needed so it is possible your nearest dealer may not have immediate access to the necessary hardware.
Anyway, I had the Matrix lights on an A8 loaner and as has been said, they are a big step above bi-xenons.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 12th January 2017, 01:10 PM
I've got VCDS if you'd like to scan it sometime Mark, can always meet up after work
Old 12th January 2017, 08:30 PM
Thanks Neil, I am hoping it will be going in tomorrow or Monday, but good to know you have VCDS for the future - they are sorting out a suitable loaner for me - I have asked if they have a Q2, as not driven one of those yet. They will definately tell me what the issue and fix was, as have corporate relationship with them too, as discussed when we met. They are ordering some rear footrests for me too - got the bug after going in your car! - they are on back order though, so waiting to see what date they get given.
Guys - I washed car well at the weekend to ensure nothing to do with dirt, no difference, and couldn't see anything amiss with the sensor either, but strange one side appears to be working as it should.
I will update the thread as I get more info.
Mark.
Old 13th January 2017, 07:23 AM
If one side is working as it should my money would be on the light unit itself - or at least something specific to that side. If the sensor was faulty it would lock out both sides?
