Old 21st January 2017, 09:55 AM
Jon_viola Jon_viola is offline
Default 4.2 Tdi Auxiliary Heater
Hi,
My Auxilliary heater seems to be running still after an hours driving. Is this ok? It seems to me that it is using fuel unnecessarily.
Is there a way to change the settings? I can't find anything in MMI
Thanks
Jon
2007 4.2tdi Quattro Sport.
Valcona black leather, Extended leather, Sports comfort Seats, Fr&R Heated seats, 20" wheels, BOSE, Media Interface, TVIM, DAB, CD changer, Bluetooth, Reversing Camera, Auto dim mirrors, Blinds, Soft close doors, Elec Boot, Keyless entry, Finger print read, TPMS, BI Xenon Active lights, LED indicators, LED puddlelights from door mirror when door closed.
Old 22nd January 2017, 12:00 AM
H-M3 H-M3 is offline
i dont think my one works
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 22nd January 2017, 07:29 PM
It should be automatic, so there are no settings, and I see no reason at all why it would be running.
Stupid question, but it is definitely the webasto chugging away, and not the suspension air compressor or something else over running ?
Have you run VCDS against it to check for errors ?
Old 22nd January 2017, 08:28 PM
Yep definitely coming from the Aux heater exhaust, front drivers side just in front of the front suspension mounts
Old 22nd January 2017, 08:58 PM
Lee S Lee S is offline
You can override the usual automatic temperature based activation by using the Auxiliary Heating menu in the AC part of the MMI. Could it be that it is constantly set to on? Do you have a little flashing heater icon on the main dash display by the time by the rev counter (I think?). Otherwise could be a faulty temperature sensor as it is set to come on under 5 degrees and as long as your low fuel light/warning is not on.
Lee
2017 Nissan Leaf Tekna
Old 22nd January 2017, 09:05 PM
Thanks for your reply. I don't have any control under the AC menu on the MMI.
I am in the process of getting VAGCOM I'll know more then.
Seems like a sensor out though doesnt it.
Anyone know a part number or cost?
Thanks
