Old 23rd January 2017, 11:20 PM
27litres's Avatar
27litres 27litres is offline
Default Who knew the MAF had such power?
Had an interesting fault over the last couple of weeks which lead to a new appreciation for what my MAF does:
It started one day driving home, it was just after I had discovered the kickdown switch on the auto and had been busy playing with that!
I pulled out of a side road onto the local 'highway' (Burwood Highway is just a glorified main road - 6 lanes in this particular location with 80kmh (50mph) speed limit) and booted it a bit at about 3/4 throttle.
At about 75kmh I was anticipating the change into 4th when "Thump"...
I backed off immediately and assessed the situation.
Car was running Ok. I saw a rev drop indicating change to (probably) 5th. 'D' was still illuminated normally in the bottom of the DIS (so no limp mode). Then the ABS and ESP lights came on and stayed on.
This all happened in a couple of seconds and I was still rolling along somewhere between 70 and 75 kmh, so I gingerly pressed the throttle and it seemed Ok, so I continued driving and other than feeling a bit 'doughy' it performed Ok for the rest of the journey home.
So I scan the car and look at the ABS module and get the fault: 18265 (P1857) Error Message from ECU.
The TCU gives the same code.
Rosstech tells me to look at faults in the ECU (der!).
The ECU gives the fault: 16486 (P0102) Mass Air Flow Sensor (G70) Signal too low
It turns out the signal from the MAF is not only used for fueling, the ECU uses the data to estimate engine loading (and therefore torque) and feeds this data to the TCU to optimise transmission shifts and to the ABS module for traction control.
I had no idea the MAF had such functionality!
So I drive the car for two weeks with the faults only using it for local journeys (mainly for fueling, couldn't care less about the ESP or ABS! ...However did we cope before ).
The new MAF takes about 20 mins to fit once it arrives, start the car and the ABS/ESP lights finally extinguish!
On driving since, you can certainly feel the difference in how the transmission functions - with the faulty MAF the transmission was softer or doughy in its shifts. With the MAF replaced, the shifts are crisper. Only someone in tune with the car could tell though.
The car also starts much easier - it was stumbling into life with the faulty MAF, taking more turns to fire than normal and only achieving a slow idle. If I tried to engage gear straight away, it would stumble and try to stall.
With the new MAF, it starts much quicker and revs through to about 1200rpm when it fires before settling at about 900. Doesn't stall if gear is engaged immediately either!
So there you go, seems the MAF is important after all!
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 24th January 2017, 08:29 AM
Yeah it can be surprising how dependent the ECUs are on the MAF for things to work properly. It doesn't always log a fault code either - mine had a lumpy idle because of the MAF giving bad data but it was quite tricky to track down because at a glance the figures looked plausible. In the end, turning off the O2 sensors and forcing it to run open-loop proved the point. Interestingly, unplugging it and triggering a code will cause it to ignore the MAP until the code is cleared, even if it's plugged back in.
Changing the MAF to cure bad shifting was a trick amongst Audi master techs back in the days when D2s were still going through the dealerships.
Old 24th January 2017, 09:56 AM
27litres's Avatar
That reminds me, I haven't cleared the codes yet - job for Friday (day off)!
Marty
Family:
Sold:
1997 Audi A4
Old 25th January 2017, 04:01 PM
Turbo Tony's Avatar
CRC make a MAF cleaner spray, which I had good results with
Storytellers Villa Orlando
2008 Audi S8
Old 25th January 2017, 08:37 PM
27litres's Avatar
Yeah, got some!
Didn't work in this case!
Marty
Family:
Sold:
1997 Audi A4
Old 25th January 2017, 09:42 PM
RS6's Avatar
RS6 RS6 is offline
Yeah maf is very important, on some of theprevious cars i've had on rolling road days, power figures are down, change the maf & boom! back into the land of responsiveness!
Abarth 500 Esseesse - Sold
RS6 Avant Black - Stolen
Mercedes Benz CLS 500 - Sold
Corsa VXR Nurburgring - Sold
RS6 Avant Grey - Sold
Seat Leon Cupra R - Sold
