D4 - Everything Else Holding forum for all D4 banter until membership grows and we'll expand out |
Hi all,
I have a 2012 4.2tdi and I can't seem to find anything at all on auxiliary heating for the D4? I am wandering if it comes with the burner as per the D3 my D3 was a 4.2tdi and I installed the pump and piping and had it coded and added the remote control.. Any help to achieve similar would be appreciated thank you. Ian |
I don't think the D4 came with a Webasto in the UK, pretty sure mine doesn't have one. I think the auxiliary heating is electrically powered!?
Hmm interesting. I found several units online readily available from Europe at quite a reasonable cost, is there any kind of guide for fitting?
I drive a lot in winter in Germany and it can get very cold (-20) in winter and I'd like to be able to warm the block and oil before starting. As well as the interior of course! |
I think Paul may be right, just had a look on my 2011 3.0TDI and no sign of a Webasto sticker anywhere under the bonnet. My old D3 had one as does the wifes Q7 4L.
More likely the bean counters decided on its omission rather than an environmentalist. Pity. |
Not as good as webasto but as Paul says - D4's have some sort of electric heater as mine blows warm air as soon as I start the car, which is nice as the 4.2tdi takes ages to get up to tempareture
In terms of a cabin heater, it's not an issue for me either as my 3.0 D4 also gives warm air very quickly. I would consider the real benefit of the webasto unit is having warm coolant circulate around the engine block. This would surely be beneficial for an engine in the long term in terms of wear.
