Old 8th February 2017, 09:01 AM
madcjd madcjd is offline
Default Loss of sat nav after battery change?
After replacing the battery, and correctly coding it to car, I've lost my sat nav! Everything else works fine. Is this something I could resolve by use of hidden menu (just asked for 'how to' access hidden menu too)?
Previous cars
A8 D4 4.2tdi lwb (2011)
T5 Caravelle exec 2.5 (2006)
A8 D3 4.2 quattro (2003)
A6 4.2 quattro avant (1999)
A6 2.8 quattro (1998)
Audi Coupe 2.6E (1993)
Carlton 3.0 GSI
Old 8th February 2017, 10:02 AM
There's no reason why you should lose the SatNav after replacing the battery! You might lose the clock in the instrument panel but nothing else.
Thus:
1) A VCDS Scan would be best for full diagnosis,
2) Failing that, run the 'Red screen' scan to see if the Sat Nav is on the MOST BUS.
Julian
Old 9th February 2017, 12:41 PM
I'll give that a go. Thanks
Previous cars
Carlton 3.0 GSI
Old 9th February 2017, 01:14 PM
I would just disconnect the battery for a few minutes and reconnect cleanly, no bouncing and scraping sparking of contacts, just bang it on and tighten the bolt - worth a try, the theory is a 'dirty' reconnect may crash/scramble a module.
Old 9th February 2017, 01:18 PM
Sounds like a good theory. I'll bear that in mind..........thanks
Previous cars
Carlton 3.0 GSI
Old 10th February 2017, 07:31 PM
I've had a weird thing since disconnecting the battery on my D3 whilst on Holiday last year.
Everything works, except that the TMC indication when the MMI is switched on disappears completely when no TMC signal is present, and the outlined box pops up when TMC is being received rather than switching between the outlined and filled TMC box.
I must try and disconnect it again at some point to restore normal operation. Seems that disconnecting the battery can reset all sorts of oddities.
