Go Back   A8 Parts Forum > A8 D4 > D4 - Axles, Brakes, Suspension and Steering
D4 - Axles, Brakes, Suspension and Steering Brakes, Springs, shocks, steering racks, steering columns, suspension arms, wheel hubs etc.
Old 8th February 2017, 11:14 AM
A8 Ian A8 Ian is offline
Default Steering judder on full lock
Hi All,
In my D3 on full lock I had the usual quattro judder, on my D4 the lock is much better than the D3 but on full lock I get this horrid feeling like it's skipping across the road..
Kind of like when you see an artic lorry go full lock and you can see the wheels simply can't turn so they kind of scrub ..
Well I can't think how to explain it but it's not very nice..
Is this normal or do I need to get it to Audi?
At car parking speeds I should point out!
Thanks
Ian
Old 8th February 2017, 12:10 PM
Doesn't sound normal to me, very occasionally I have felt a bit of a judder on full lock - but it seems surface dependant - not all the time
Old 8th February 2017, 05:33 PM
Joe2.0E Joe2.0E is offline
Agree, as you describe it, it doesn't sound normal. I consider the "AWD" judder on a D4 is less noticeable than on a D3.
Old 9th February 2017, 05:28 AM
Interesting. . I will have to try it on a multitude of surfaces and see if it's that or something that is a problem.
Thank you i will get it checked out
Old 9th February 2017, 07:37 AM
Check for uneven tyre wear, won't take much scrubbing to show up that way
Old 10th February 2017, 06:45 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Is it during all outside temperatures? My D3's front end with 255 section tyres does sort of scrub on full lock when its close to 0 degrees at low speeds. First time I thought i'd hit something!
2007 Mini Cooper S R56
