Go Back   A8 Parts Forum > A8 D4 > D4 - Everything Else
D4 - Everything Else Holding forum for all D4 banter until membership grows and we'll expand out
Old 25th February 2017, 09:25 PM
A8 Ian A8 Ian is offline
Default Tow bar retrofit
Hi all,
I can't find a definitive guide to fitting the electronic swivel tow bar on the D4 ... I have bought a tow bar and the button that resides in the boot.. but no idea what else is needed to get a nice oem install..
Can anyone help? I have no access to diagrams or anything and will gladly post a guide for my installation if anyone can offer any help
Thank you
Old 25th February 2017, 09:41 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Paul (PaulRsTaylor) fitted one to his D4, I'm sure he'll be along to help if he can... Maybe PM if he doesn't. It is such a s****y bit of kit!
2007 Mini Cooper S R56
Old 25th February 2017, 11:06 PM
Pages 226 & 227 of THIS DOCUMENT may help a bit hopefully
Electrical parts should be covered HERE on pages 85-90
Old 26th February 2017, 06:08 AM
Thank you, certainly helps with regard to fitting the bar itself.
Do you know where the towing module resides? If there is one of course.
Old 26th February 2017, 10:44 AM
For a pre-2014 car you need the following:
  • OEM tow bar (ebay.de)
  • Button (ebay.de)
  • "Trailer" ECU (p/n 4H0 907 383 C - ebay.de)
  • Kufatec Loom
  • Possibly an additional fuse strip if you want a full OEM install (Dealer)
  • Bolts (Dealer)
The ECU sits between the boot and the rear seat bench to the left of the ski hatch, kufatec supply outline installation instructions with the loom.
I can help with coding if you need it, but be aware that the coding will get reset when it goes to the dealer - easily reset or you if you can get a friendly dealer to add "KF7 - Coding for trailer hitch" to the PR codes for your car.
Post-facelift have different part numbers for the ECU, need a different loom and installation instructions, but the actual towbar and button are the same. I have a post-facelift ECU in the garage
Old 26th February 2017, 11:02 AM
Edited to say, physical install is a couple of hours labour - wiring is a faf and expect to spend some serious time in the boot of your car in very uncomfortable positions (as I did), or to have to remove the back seats to get access to the read of the fuse box!
The install is as OEM as you could hope for, but you will need to book time with a chiropractor afterwards and not something I'd ever want to repeat!
Old 5th July 2021, 06:51 AM
ctjfb ctjfb is offline
Apologies for replying to an old thread - but it seemed very relevant :-)
I'm in the middle of retrofitting a factory swivelling towbar to my 2016 A8L TDI , using the KUFATEC wiring loom, and have a couple of questions .
Having drilled the 40mm holes in the plastic boot lining for access to the inner bolts it seems that the aluminium structure behind has not been machined to allow the bolt to pass through the 'tube' and bolt into the towbar 'arm'. The 'tube' is closed at the far end. Hard to describe really, but anyone who has fitted one of these should understand what I mean :-)
I have drilled out the end with a 14MM drill so that should be OK, but I'm really curious to know if anyone else has come across this as every A8 D4 towbar instruction manual I have found has no mention of this ...
I'm also told that coding has to be done by the dealer .. I can find no instructions .. I asked on the obdeleven forum but had no reply. The KUFATEC loom uses the early pre-facelift controller - and they assure me that this works perfectly with the post facelift cars as the two units are logically the same. So if anyone has experience in coding a pre-facelift car that might be really helpful also !
Thanks in advance for any pointers of info.
Chris
2016 A8L SE Exec TDI
Old 5th July 2021, 07:15 AM
Anyone with ODIS access can do the formal full coding to Audi back office - my local indy in West Sussex has the kit (needed to do it for retrofit of a RVC kit to my Golf GTI)
Can't help with the other queries, I'm afraid, although been thinking I've had my S5 so long I should fit a towbar for bikes......
Old 5th July 2021, 07:31 AM
Many moons ago I fitted a swivelling towbar to my D4. My lasting memory was the degree of contortion required through the process, both for the bolts mentioned and of course, getting the wiring into the fusebox which was far from comfortable.
Coding wise, I used VCDS, logically going through each module and adding the towing byte, assisted by the Kufatec instructions. It worked a charm until it went in to the dealer next when they reset everything and lit the dash like a Christmas tree! As I was on good terms with them, they fixed this by adding the factory PR code on their system and resetting again.....
As for a pre-facelift on a post=facelift car - I can't say for sure, but I do have a facelift ECU in the garage somewhere, although no-longer have a D4
Old 5th July 2021, 10:05 PM
I believe that A8 Ian no longer looks at the forum.
I could be wrong.
