A couple of issues, other than cosmetic, have cropped up now I have been driving the S8 for a couple of days.
1. The temperature gauge is temperamental - sometimes it works sometimes it doesn't - I haven't noticed a pattern? 2. First start in the morning from cold (seems OK at other times) the engine catches and the revs rise then immediately die away and stalls - try with a little throttle and starts OK? Any help or advice would be very much appreciated. Neil |
Could be faulty coolant temperature sensor that causes both issues.
I'd agree with that; based on my experiences get a genuine one from a VAG dealer not a cheap eBay version.
It's actually a dual sensor, the visible gauge and ECU signals come from separate components, so it can be quite confusing. Fairly easy to change; I think I documented some tips in a thread somewhere on how to do it without losing small clips down the back of the engine, and not losing any coolant. ![]() Edit: All in this thread: http://forum.a8parts.co.uk/showthread.php?t=1157
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 17th May 2017 at 08:05 AM. |
I just tried changing mine last weekend. I read the quattroworld procedure, 5 minutes job my ar$e lol. The little bu@@er must be the original one from 16 years ago and its properly corroded in there, it would not budge. So I left it in for now.
http://forums.quattroworld.com/a8/msgs/39064.phtml I am going to try anti-seize solution, namely a mix of around 70% vegetable oil from supermarket and 30% acetone (nail varnish remover). Its worked wonders on a few other things so far. My only slight worry is the housing the temp sender is jammed into appears to be plastic I hope the small amount of acetone doesn't harm it. So I don't want to scare you but be prepared for a fight ![]() I hope your one is not corroded and easy to remove. Last edited by Goran; 17th May 2017 at 10:00 AM. |
Yep, it's a pig to get out. And you have to be careful not to rotate it or snap off the plastic part too. It'll seem like it's not budging at first but eventually it pops out after a lot of wriggling and pulling. More importantly, make sure when you fit the new one that the crappy plastic retaining clip is properly secured, if you don't want to end up on the hard shoulder like I did: http://forum.a8parts.co.uk/showthread.php?t=9845 The clip on mine kept working loose, despite being fully locked into place. I'd recommend putting some heatshrink sleeving over it just in case like this.
Another thing to bear in mind is that though it "should" be easy to wiggle out, once the clip is removed, with the engine cold the reduced pressure might create a bit of suction.
So worth undoing then reclosing the coolant filler cap first to equalise pressures. Or if you have an assistant (glamorous or otherwise) get them to open the cap slightly and be ready to close it again very quickly as soon as the sensor gets moving.
