Hi,
Can someone tell me which is the correct Right Side Rear door lock actuator for my 2006 S8, Reg; AD06 YMC. Looking at realOem there are two options: 4E0839016 or 4E0839016A hoping someone can advise what difference if any as the non-A part is more readily available. Thanks
Present cars Daily driver: BMW e65 730d Batmobile: 2006 S8, D3, 4E 5.2L V10 BSM with (loud) Miltek SS exhaust, Carbon Fibre trim, Alcantara headlining, soft close and keyless entry. ![]() |
http://www.realoem.me/Audi/CA/A8Q/20...R/8/839/839030
Depends on VIN no. and options.. (K8L = LWB, K8B = SWB) |
VIN WAUZZZ4E67N003566 Manufacturer Audi Model Audi s8 qu. 5.2 Manufactured date 10.07.2006 Model year 2007 Exterior color / Paint Code L8 / Z9Y Year 2007 Equipment KD Axle drive 6A Roof color L8 Sales type 4E2SSL Transmission Code JLM Date of production 10.07.2006 Engine Code BSM Model code A8 PR codes 1A2 GS1 6E3 9WC 4UF Q1D D5W 7A2 QW1 1X1 5Z0 1Z6 4V0 0GG 1T3 FC0 8Z5 K8B 8T1 7QT A8S 4L6 GZ2 T8E 1KZ 3D1 B0N 0TD 7AL 5D1 VA0 GT2 3B4 S0C 6XL 1LK 6FC J0Z 6W6 2K3 2WA 9M0 3G0 QH3 1C1 4K6
I still cannot make sense if the RealOEM site as it looks like either unit can work. Can anyone advise on how this site is to be used as the information seems inconclusive. Thanks.
Well, I removed all the left sides, armored vehicles, LWB and 2007> and we are left with ...
(1) 4E0839016 door lock with door contact switch, F >> 4E-7-010 181* right ;;1 PR-GZ0 (1A) 4E0839016A door lock with door contact switch, F >> 4E-7-010 181* right ;;1 PR-GZ2+K8B If you look at your PR codes, it is GZ2+ K8B = 4E0839016A PRCode: GZ2 = Door power latching seems to be the clincher - do you have soft close? |
Hi - Yes only discovered today that soft-close actuators are fitted to the car(!!), I don't think the previous owner knew this either... - this feature never worked in my few weeks of ownership. Didn't know it was there. p lease see my other post regarding the soft close for more detail. I only discovered this feature as I had removed the door card today to see what door lock P# I had fitted - didn't get far after discovering soft close feature fitted (then the rain started). Any ideas on why none of the soft close doors arnt working? what should I check? The Rear Right door never locked at all with the key fob or central locking. do you think the door lock could be issue? Any guidance greatly appreciated.\\Cheers,
