Old 28th May 2017, 06:53 PM
Default FL D2 plastic door handle inserts: 2 part or 1 part?
D2 FL cars came with two types of internal door handle inserts:
1. fake wood 2. plastic.
I have fake wood ones, but wanted to shift to plastic.
Do I understand correctly that plastic handle inserts from late FL D2 cars are made of two parts?
Here is an example of 2 part set: http://www.ebay.co.uk/itm/132008422603
However this set comes from 1998 car.
Are the facelift ones different?
Old 28th May 2017, 07:14 PM
Well those are being sold by our sponsor so give them a call and ask, they will DEFINITELY know.
That said, I don't understand the question, those look like normal door inserts to me and I thought they were all the same (apart from painted vs fake veneer as noted).
Finally the set linked too looks a bit flaky on the front passenger switch panel.
What exactly do you want, I have several spare bits of that type in beige plastic that could be repainted? I definitely have the switch panels and probably the bottom shells too.
Edit: Ah, I see what you mean now! Just looked at the listing again.
The ones I have, which are from a VERY LATE FL D2 have a single top section/moulding for both the switch surround and grab handle hole. Then you just have the bottom piece that feeds up and joins it, so 2 parts per door, not 3!
Old 28th May 2017, 07:34 PM
Thanks Andrew,
Yes, I basically looking for all-plastic inserts from very late D2s (or Final Edition), which, as you just confirmed, are single-top-section design.
Is anyone selling?
Cheers.
Old 28th May 2017, 09:49 PM
Is anyone selling?
Me? But will beige do? If so I'll dig them out and post some photos.
Old 28th May 2017, 10:11 PM
What colour wood / plastic do you have now? I'd happily swap black plastic for maple on black, although mine would need painting to bring them up to your standards...
Old 28th May 2017, 11:05 PM
I plan to paint them, so colour is not important.
Pictures how they actually look like would be great.
I haven't seen these plastic handles.
Can't find them on ETKA either. Found only fake wood handles there.
Old 31st May 2017, 09:16 PM
Hi Sergey
I am confused about this thread, but I do have a set of genuine late FL (FE) plastic door inserts available. I replaced mine with 'dark maple' fake wood inserts and was planning to refurbish the plastic ones. But those plans are now abandoned as I like the 'wood' insets better.
Let me know if you're intersted.
Best regards, Jim
Old 31st May 2017, 09:21 PM
Jim, I expect yours will be like mine (but a different colour - black?) so will have the top surface actually painted metal. Have a careful look at them.
Sergey is trying to find parts that are 100% plastic to make painting/repainting easier. Though I would have thought that, with the right paints, it wouldn't matter.
Old 31st May 2017, 09:29 PM
Hi Jim.
As Andrew explained, I decided to use pre-facelift handles that are fully plastic and can be taken down to basic components. In the middle of previous page I showed 4 pictures of what I mean.
I ordered some parts from A8 Parts and from Audi Tradition to do this project and if I succeed I will do a write up.
Thanks for offering the handles. If my project will fail I will take yours.
P.S. I thought your car is dark Myrtle wood actually?...
Old 31st May 2017, 09:39 PM
A lot of the later cars (and maybe earlier ones too?) had just plain painted panels around the door switches, the same colour as the surrounding plastics.
Mine did originally but I swapped them for wood effect.
