just for people installing a rear camera this one looks like a direct fit.
I purchased one of ebay and I had to spend a couple of hours with a dremmel to make it fit don't like the non oem looks so this looks good. https://www.aliexpress.com/item/Car-...08.3.10.YnZVaF |
yea got mine fitted today using the xcarlink for the reverse switch pity I didn't see this camera before I started using a camera that did not fit right and the led light part doesn't even work it just started to flash then nothing
EDIT: Looks like it's not for the D3
Anyone tried this camera? http://www.ebay.co.uk/itm/351409588411? ![]()
Matt 2004 A8 3.7q, 1998 A4 2.8q, 1994 Coupe 2.8q SORN, Last edited by mattylondon; 5th July 2017 at 11:21 AM. Reason: Camera for D4 |
Whete do you connect this and what else is required ?
Owner of a 2008 A8 3.0tdi SE |
Pretty sure the car needs to have a TV Tuner to display the output on the MMI Screen. The Parking Sensor Module might also needed to be changed to enable the camera display when you select Reverse but it may be just coding to enable this function.
