Hi guys. I'm wondering if someone could plug their 4.0 or 4.2 TDI in and tell what the RPM of the engine is while cranking. When the 3.0tdi A4 is cranknig it spins over very fast in comparison. (keep forgetting to plug in and see what speed it turns)
My hot starting problem is getting worse and worse and worse. The other day, after having sat on the drive over the weekend it wouldn't even start from cold. The engine sounds slow and gets slower. Tonight after trying to start it I plugged my wee code reader in. On its own battery it started off turning at c150RPM and by the time it decided it wasnt going to start it was only doing c120RPM. With the jump leads on the A4 it started turning over at c170 RPM slowing to the mid 160's. It isnt even starting with a jump until it has sat and cooled for 3-4 hours. Also, I used to be able to start from cold at work, then stop at the supermarket on the way home, by which time the engine had heated up to around 70 degrees and was still able to start it after doing the weeks shopping. Now it takes several attempts and usually needs the booster battery to start. Ive bought a new starter motor for it. I'm not one for blindly throwing replacement parts at a probelm in the hope of fixing a problem but it was really very cheap so i thought i moight as well take a punt. Taking it to the "experts" to have it scanned on dealer level VCDS software gave me no information and the crank sensor did nothing to help so if this doesnt work I'm seriously considering scrapping the thing. gill |
If it cranks faster using another car as a booster, then your battery must be bad.
Try charging it fully, either by a long drive (3-4 hours) or put a charger on at least over night. If the problem doesn't go away, you need a new battery ![]() But as you have thought of yourself, a worn out starter motor will crank considerably slower than a new one.
06 A8 3,0TDIq My daily driver and project... 97 A4 1,8Tq. Powered by a 4,2 from the '01 S6, full rollcage, FIA seats and 6-point harnesses, B5 RS4 KW Competition race suspension, B6 S4 brakes, 18" Toyo RS1 slicks, carbon fiber roof. V8 trackday racer ![]() 14 VW Caddy 1,6TDI from my employer.. (X)00 A8 2,8q, (X)97 A4 1,8Tq, (X)92 S4 2,2Tq, (X)92 80 2,3E |
When fitting the new starter, it would be worth replacing the earth strap/cabling as a precaution also, they should'nt be too expensive.
Your symptoms sound exactly like crankshaft position sensor failing which happened on my D3. Only started well when cold and it flattens the battery everyone you crank it without starting. In the end it packed up altogether and the car wouldn't start until it was changed.
It's actually had two new crank sensors. An intermotor one which I thought might have been a fake (cheapo off ebay) and a genuine bosch one straight from the bosch factory.
Its had three new batteries in the last two years as well. The current one was brand new in I think October. I'm beginning to suspect something to do with fuel pressure but without VCDS I cant check. I'm hoping to get it in to my local garage for a scan next week sometime. Cranking speed is definitely low though I think. I'm not going to bother with changing the starter until Ive had the fuel pressure checked. gilll |
