Old 19th August 2017, 09:57 AM
A8essex A8essex is offline
Default Annoying clicking every 7-8 minutes
Arrrhgg....drives me mad. Must be 25-35 clicks in quite quick succession from behind the centre of dash and sometimes it seems behind/below steering column (RHD UK spec D2 2000MY)
Also noticed the centre vents have very little (almost none at all) air coming out even when fan is on max. Sometimes flipping to AUTO the centre ones seem to work some more but when next in car its back to nothing. (the very middle vent with the hot/cold slider works, tho is never hot)
So am guessing that maybe the centre flaps dont open properly and the clicking is related....though why it does it every 8 mins is a mystery.
Its done this ever since i got the car !...any ideas?
Old 19th August 2017, 02:10 PM
Conquistador's Avatar
Does sound like the centre flaps are stuck. Clicking could be a relay?
Have you scanned with VCDS? I'm in Chelmsford if you need a scan but haven't got it
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 19th August 2017, 03:18 PM
Cheers for speedy reply.....i one have the cable/software so be great if you could plug yours in. Heading to south of France in it next Friday so would be brilliant if I could stop it before then !!
Old 19th August 2017, 03:54 PM
Would it be this http://forum.a8parts.co.uk/showthread.php?t=1624
Old 19th August 2017, 04:58 PM
adeneo adeneo is offline
It's a common problem, it's one of the stepper motors for the air vents, they click every 7 minutes when they're stuck or broken.
It should throw a fault in the system if you have it scanned, if I remember correctly there are about five little motors, VCDS should tell you which one is making the clicking sound, and that needs replacing.
The manual says
Replace the actuator motor if it makes clicking or rattling noises in regular intervals (approx. every 7 minutes).
These noises originate via activation of the actuator motor via the A/C control head -E87- in actuator motor drive.
Activation occurs to maintain the flap/motor securely in one position.
Old 19th August 2017, 05:33 PM
Re - Would it be this http://forum.a8parts.co.uk/showthread.php?t=1624
Thanks for that...So happens a mate had one of those relays in his garage so after a bit of fiddling we have just swapped the one highlighted in the picture as the "most common cause" . Same issue, so either a) its not that relay or b) the relay we put in is also faulty !
Does the VAGCOM thing tell you which relay it is...and if so, how do you then know which relay is which ?
