Go Back   A8 Parts Forum > A8 D3 > D3 - Common Faults
D3 - Common Faults Quick links to all known common faults and their solutions
Old 5th December 2017, 06:44 PM
erubus erubus is offline
Default washer fluid leak
Hi guys. Another one of my cars annoying niggles. Im going through a gallon of washer fluid every two days. It leaks from either side of the front bumper. As far as I'm aware, you need to remove the front bumper to access the headlamp scooshers.
How much can I access from the wheel arch with the liner removed? - my guess is very little.
What are the likely things I should be looking for? I'm hoping for something as simple as a split hose but are there other likely culprits? I dont want to go to all the hassle of removing the bumper only to find that there is a part that I need to buy and i have to put it all back together just to take it apart again.
I'm fairly sure that it is leaking on the drivers side and is running along the bottom of the bumper and dripping form both sides.
I did seem to lose quite a lot of washer fluid in the summer, but as the lights werent on very often, the headlamp scooshers never did anything, and that seems to be the catalyst for it dumping the entire contents of the tank onto the road.
As a quick fix Im tempted to disconnect the pump for the headlight scooshers and clamp the pipe. I'm almost paying out as much for screenwash as I am for diesel!
The healdight scooshers work fine by the way, plenty pressure etc.
thanks in advance as always, gill
Daily drive: 2008 A8 4.2TDi
2003 A8 4.0TDi. 4 zone climate, double glazing, Bose - dead
Other cars: 1980 Land Rover Series 3, 2.25d, hydraulic winch,Van/station wagon/topless depending on my mood
1990 Land Rover 90 factory county station wagon with all the luxury additions, such as a clock and a tape player.
2007 A4 3.0TDi s-line cabriolet quattro
2000 A8 D2 2.8 quattro, looking for a new home - gone
2003 A6 3.0 quattro, in the way... anyone want any parts? - gone
Old 7th December 2017, 03:33 PM
neeldub neeldub is offline
Get yourself some 4mm hose joint connectors. If you have a split pipe you can join them together with the joint.
Previously:
2010 Audi A8 4E Quattro Sport TDI Oyster Grey
Currently:
2015 Audi A8 4H Sport Executive Quattro in Monsoon Grey
Old 8th December 2017, 08:23 AM
I'm pretty sure there is only one joining piece and its behind the driver side fog light grill, T piece splitting main feed from the washer bottle to both headlight washers.
Other end goes directly to the top washer pump.
Windscreen jets are plugged in directly to the lower washer pump.
Washer bottle is fairly easy accessible by turning wheel right and undoing the back/left half of the wheel arch liner (carpet one) - 3x torx screws.
No need to remove the wheel, but you can if you want to make it super easy.
I doubt it's a split hose, 90% is the T piece behind the fog light grill which is easy to access by just removing the grill and hose with connection will be just at the bottom behind the bumper held by a metal clip, at least it should be, but I've seen them clips missing before.
On the pump sides you have the fuel line type connections and they are very good.....unless previous owner or garage messed around them.
Very unlikely split washer bottle.
If it's the connection behind the fog light then that would only leak out about 70-80% of the fluid because headlight's pump is located higher than the windscreen one.
Good luck
Old 8th December 2017, 08:42 AM
There's another connection that can also sometimes be forced off at the top far left scuttle as you look under the bonnet - its where the pipe goes up and along to the main windscreen washers. mine popped off once there.
Old 8th December 2017, 08:44 AM
Sorry, yeah, you are right Neil, completely forgot about that one
Old 10th December 2017, 09:48 AM
thanks guys. its definitely the headlamp washer end thats leaking, it runs out onto the bumper and drips out in front of both front wheel. occasionally it decides to drop all the fluid out of the reservoir but its only done that a few times. Mine is a prefacelft with the two seperate grilles, can I still access the t-piece without taking the bumper right off?
when i fill the reservoir i get about 8 hours before the light comes on on the dash. that then lasts a few days (in this weather, with all the salt on the roads, the windscreen needs cleaned constantly) The headlight washers work perfectly when the level is up which is why i thought maybe a split hose. Apart from the warning on the dash being really annoying (and the beep noise every time the ignition goes on being even worse), the headlights are terrible in the best conditions, so with them not getting washed they get filthy very quickly and the available light is diminished even more. 95% of my driving is on country roads tghat are covered in mud, with muddy verges so good light is a must (no white lines at the edges of the carriageway etc)
