D4 - Sat Nav, ICE, Audio & TV All in car entertainment discussions including MMI 3G Plus |
Hi all,
First of all, Happy New Year. I have just purchased the above dash cam, along with hardwire kit and 32gb card. I have just read the other install instructions a couple of posts below and have a few questions. I don’t have the garage door opener, so would there still be the required bits of the harness up there to tap into, how do I remove the overhead console to get at this, and lastly I am also considering the item below, which if there is room could be installed instead of the hardwire kit and then just a short external usb to mini-usb cable connecting from this to the dashcam. My thoughts are, if I am going to drill a hole in the console, I may as well make it universal with the option of leaving in situ once I sell the car on in the future, rather than leaving a hole or the dashcam installed. any thoughts, hints, tips etc. http://www.mobilecentre.co.uk/index....roducts_id=663 Cheers Mark. |
I'm not sure if there is an alternative switched live source without the homelink, would need to check the wiring diagram or just break our a meter!?
I didn't drill anything, the cable fitted "down the edge" nicely. In any case, a USB socket up there would probably put me off a used car as screams "modified" wiring to me..... but each to their own ![]() |
Thanks Paul, sounds like the USB option is not a good one then - I had assumed you had drilled a hole and put a grommet the same as the link in the Blackvue post.
Can you recall how to remove the overhead console so that I can have a poke in there with a meter to see if there is a switched feed anywhere - maybe the sunroof? Cheers Mark |
From memory, a single torx screw behind the sun glasses holder - I can take a look tomorrow if you can't see it
Thanks Paul, I will take a look later on when it gets a little warmer.
Cheers Mark ![]() |
As always, Sod’s Law has played its hand. Went to car a little earlier to open up the sunglasses holder and it wouldn’t open - I don’t recall ever having tried it before, as from my last D4, I knew that my sunglasses don’t fit. After a little pressing etc it came open, I saw the Torx head screw, but haven’t touched it, as the sunglasses holder now won’t stop up, so going to have to get this fixed under warranty first, as don’t want to show any evidence of messing in there, even though I haven’t.
It is now taped up to stop it fouling the rear view mirror - which looking at it must also have a 12v switched feed to it, as it lights up when you turn the car on. |
